70&22bronco
Fallon
1970 Bronco
These look like the same hoop steps on my Ranger Tremor Package. They do attach to a rock rail (the Ranger's rail is different so I am guessing the mounting angles on the back are different). They are Line-x coated, VERY strong and durable. Price looks good too.
That’s good to know, thank you! I didn’t want to lose my rock rails, so these seem like a great option to help my girls get in. I’m scared to make any changes to my order, so I’m hoping I can buy them later from Ford. 🙂
boxwood
GA
EV
Not that B&P images are 100% accurate, but here is high-res closeups
Ford Bronco Bronco Gets Removable Hoop Step Option From Factory 1645577237323
Ford Bronco Bronco Gets Removable Hoop Step Option From Factory 1645577000903
Ford Bronco Bronco Gets Removable Hoop Step Option From Factory 1645576256219
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Good option from the factory! I still prefer the AR ones for looks and function (2 height settings plus easy to remove and install)
NaturalFlorida
Dale
Vero Beach
1985 4Runner SR-5 / 7" lift / 5.29 Gears / Lockers
The tube doors for the two door went up 75%
That haven't grown on me enough to get a set
Still holding out for a 1/2 door filler like the Roadster
Theherofails
Thomas
Phoenix
The attachment does look a bit better than the Tremor, at least. These might be usable from that perspective.. but they're going to get caught on everything. Logs, rocks, small children.
fergthulhu
Sean
Aurora, CO
'22 Badlands, '21 Ranger Tremor
If they go on the same way (looks to be the same step), it's not exactly what I consider easy. Still involves laying in the dirt to take them on and off before/after every trip. It helps to use a battery powered socket wrench like the Milwaukee M12.
Also, I'm curious how the backwards compatibility will work as these need to be bolted into the rock sliders, and the existing rock sliders lack those holes.
On my Tremor, the holes for the step created a weak point in the sliders and I actually bent my rockslider fairly bad when I hit a rock without the step installed.
I mean, you guys are grown ups and you can obviously do as you please..I'm just letting you know the perspective as pretty much one of the only guys wheeling a Bronco right now that's also wheeled those exact steps before.
On the Tremor, they bolt in from the bottom with 2 fairly large bolts, so you need holes through the top and bottom of the rockslider to attach the steps.
These look like they attach differently, but I agree. They were pretty worthless on the tremor, super light-weight, attached to body, and when you removed the steps would leave large cutouts in the rails. They were pretty much the only part of the tremor package that I didn't like. I know his name gets bad press on here, but even on Mike Levine's tremor he took them off right away, lol.
Again, these look similar...but could be different. If they are like the tremor rails and you plan on off-roading where you would need a moderate amount of clearance, I would avoid them. If you're not off-roading and need steps then they should be fine calf-scrapers.
Theherofails
Thomas
Phoenix
It looks like they attach through the side of the rail now instead the bottom.. so at least removal is easier. With that said, they still stick down below the rock slider and stick out too far.
I said the same thing to Ford Engineering when I had a chance to talk to them about it. The steps look great, but are TERRIBLE on an off-road oriented vehicle.
I taco'd my rock slider right where the front driver step attached due to the weakness created by adding the mounting locations for the steps. Otherwise, those were fairly decent rockslides for factory.
If someone's idea of off-roading is driving down a sandy Florida beach, these steps will work great. If you have to rely on ground clearance.. Oof. They catch EVERYWHERE.
AzGoat
Seattle
2003 Suburban 2500
Weird. I was close to pulling the trigger on the AR Stirrups but can't make up my mind.
I had a hard time deciding too until I saw the steps hanging below the sliders. I dont think AR's on the highest setting sit below it. Plus, the AR's are very nicely made.
t3n2and4
VJ
Washington
www.instagram.com
Badlands, F150, VW CC
I’m very intrigued. Sunday we drove friends to lunch… and I didn’t realize that the truck was impossible for a shorter woman without a step.
bytheway
Brice
Louisville, KY
I was interested until seeing them on the tremor. I think out of the 3 options I prefer the IAG right now.
Ford Bronco Bronco Gets Removable Hoop Step Option From Factory 7ihf5MK
Ford Bronco Bronco Gets Removable Hoop Step Option From Factory NK5AcgC
boxwood
GA
EV
Are they referred to as "removable" on the Tremor.
