- Jul 16, 2020
- 0
- 267
- 623
- Georgia, USA
- Camaro SS, Indian Chief Vintage, Yamaha Fz1, Honda Shadow, etc
- Undecided
Thats dependent on the year and cab size for the Raptor though. 1st gen Raptor had I think as high as 1700lb payload at some point, and the 1000lb payload for 2020 is on supercab. Super crew is 1200lbs payload(also 8k tow cap super crew vs 6k tow cap on super cab). And being the higher output motor could be more to do with that than the off-road bits, the raptors engine is available in the limited now(so not off-road oriented, just the same high output engine) and tows less and less payload than most of the other f150 engines(less payload than even the 2 engines it has higher tow cap than). And that’s similar to some other trucks, same engine in different trims/models can actually be rated to tow more with a less hp version of that engine. Payloads only 300 more in the limited with the high output 3.5 vs the Raptor supercrew.True, but it's not far off from some off-road focused full size trucks. The payload of a Raptor is only about 1000 lbs.
