Msemmes
Michelle
Toyota 4Runner
I always thought the black beauty rings on the Wildtrack and FE looked better than the silver that I was forced to buy with the Badlands Sasquatch package. I decided my first project would be to paint them black, despite having no experience with paint and not being particularly handy, because of the following:
* The only beauty rings I've found from Ford accessories were red
* If I really messed it up I could replace them or eventually be able to buy the manufacturer black ones from Ford direct.
* I think matching the trim ring with the wheel color has a more utility less refined look that I dig.
* To us Bronco6g nerds, I will be the only 2021 Badlands Sasquatch Area 51 with black bead lock trim rings for the time being - differences being black ring with a carbonized grey grill, badlands badge, black door handles and matching gloss black wheel color. The Wildtracks have the black grill and color match door handles as far as I can tell?
1. bought scotch brite srubber to scuff up the silver rims: https://www.homedepot.com/p/Scotch-Brite-Stainless-Steel-Scrubbing-Pad-3-Pack-214C-CC/202511523
2. Behr black Paint + Primer
3. T45 Torx bit. (unbelievably despite having a variety of torx bit sizes in the Bronco toolkit it doesn't include this size): https://www.autozone.com/screwdrivers/driver-bit/p/duralast-3-8in-drive-t-45-torx-bit/864636_0_0
Here are the before and after. Super happy with the look.
AFTER:
Iā€™m with you! Love the black. Iā€™m not particularly handy but someone suggested using plasti dip and if I didnā€™t like it I could peel it off. Iā€™m hoping I can do this without removing the beauty ring. Any experience with this?
VelocityBrew
Minnesota North Metro
22 Badlands, 20 Passport, 16 1190 Adventure
I just pulled all 5 of my rings to drop off for powdercoating, and noticed that all 12 T45 bolts per wheel have some level of thread lock on them. Iā€™m assuming itā€™s comparable to thread lock blue, since they are removable. I plan on reinstalling them with more thread lock . have others done this as well?
What is the torque value? I'm not big on using thread lockers šŸ¤·šŸ»ā€ā™‚ļø
Also I shyed away from powder coating because when they do get scuffed some rattle can paint and Bondo will make them right again.
luptanpitman
luptanpitman
Los Angeles
'21 Bronco, ā€˜21 Polestar
Iā€™ve seen some people do this on the horse logo on back. Havenā€™t seen it for the ring. Given how easy it is to pull the rings off I would do that first either way so you save the work of peeling. You really canā€™t mess up the removal of the rings.
Msemmes
Michelle
Toyota 4Runner
Do I need to buy a specific tool to remove them? Sorry I told you I wasnā€™t handy lol
Freebird32
Harold
97 F150 4x4, 82 Toyota 4x4 orig owner, 08 Z06
There are both Torx and Torx Plus bolts on the Bronco. You can strip head if you don't have correct bit.
BigDaddySquatch
Tony
Madison, AL
2012 Toyota Tacoma TRD Sport
You got it. Peels off clean at the body line. If I tape better there wouldnā€™t have been overspray but it just rubbed off.
Anybody done this to the Ford emblem on back? I think it would look really good all black too
akturbo
Seattle Eastside
'21 Bronco, 3500HD Chevy, Rav4Prime, Turbo Skidoo
Used a drill driver to get them mostly in and hand tightened with a 3/8 ratchet. Checked them all after a drive and seemed fine. Iā€™ll double check in a few days. Really happy with how it turned out. I was torn between black and carbonized but I think the gray captures the look of the optional badlands wheel without losing the design of the wheel to an all black appearance. I figured worst case I could always redo them black if I didnā€™t like gray but itā€™s staying as-is for sure.
Sorry if I missed it, but what paint did you use? I'll do this after I get my new tires installed next week.
bytheway
Brice
Louisville, KY
Our paint shop sprayed it single stage M7 Ford carbonized gray. Axalta paint.
broncosor
2022 Bronco Badlands
@luptanpitman thanks for this post.
Pardon my ignorance but I have a few questions:
- how is the paint holding up? Would you mind sharing a close up picture of how it looks as of today?
- assuming no scratch can I expect the paint to last a couple years or should I plan on re-painting a couple times a year? (Taking into account dirt snow and rainā€¦)
- if money is no object, would you recommend I powder coat instead or not?
- why scratch the ring before painting? How long and how much pressure do you apply to scratch?
Thank you.
604Bronco
British Columbia
www.bronco6g.com
I want to make mine the same gray as the Badlands rings.
If I keep them and not get Icons
Ford Bronco DIY How-To: Painting Beadlock Wheel Beauty Ring From Silver to Black (on Badlands Sasquatch) 0D934B60-DD26-4CF7-A688-A77D61B0076E
Just to confirm: the Badlands (with Sasquatch) rings are a dark grey and other trims are a lighter silver?
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
Im talking about the
Added ā€œupgradedā€ Badlands rims, not the Sas on a Badlands.
or the standard Badlands. They are the same as all The Sas, except the WT/FE which are Sas with Black tings
Make Sense?
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
This is what I wantā€¦ the B&P pic
Soā€¦
Nittos 315-70ā€™s more blocky-and wider tread (the wranglers have a narrow 9.5 tread)
-paint the silver rings the same as Badlands, and hopefully look more like the Computer picture.
More Fat-and -Stupid! Less Balloonish!
Ford Bronco DIY How-To: Painting Beadlock Wheel Beauty Ring From Silver to Black (on Badlands Sasquatch) 995380A2-F67A-40FB-898B-7CC623B68431
VelocityBrew
Soā€¦
I'm so confused. The left photo is an actual 315/70 Goodyear, the middle photo is a CGI 315/70 Goodyear and the Right is a 285/70 BF Goodrich. Am I missing something?
