Educate me. Pizza cutter vs Sasquach style. Pros and cons.
BeerForMyHorses
Jared
Idaho
Ford Bronco 2-Door
Am I the only one that has never heard someone refer to tires as pizza cutters?
It's a popular reference for people's that live in snowy regions. Skinner tires cut through snow better
Bronco4lyfe85
William
2019 Challenger Scat Pack
I thought "pizza cutter" was a pretty well known term for tall and skinny off-road tires.
Well, there’s the problem, I drive sports cars.
5280Bronco
5280Bronco
Denver
Thanks everyone for your input, and i think I'll probably stick with the 32s until they wear out and go from there. I borrowed a picture from another thread where someone posted a pizza cutter setup that i think was 34s and it just sparked this question (i forgot who posted it, or else i would give credit). Thanks!
Ford Bronco Educate me.  Pizza cutter vs Sasquach style.  Pros and cons. IMG_2537
Markubis
New Hampshire
Ford Focus, Ford Ranger XLT, Can Am Ryker
Pizza cutters are better on gas mileage also. If that even matters.
Me driving 90 miles total for a work commute appreciates that....but I still want something that doesn't look goofy.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
Ford Bronco Educate me.  Pizza cutter vs Sasquach style.  Pros and cons. 1603295406356
On the mini coopers, these used to be called pizza cutter wheels
5280Bronco
5280Bronco
Denver
Yeah, essentially i would want to go with something that is in the middle of that tacomas look and the sasquach eventually.
Incognito
Phoenix
2017 jk
Its funny, but I looked at where you live to try and answer your question better.....I'm in the same state...Get the 35s. I've been stuck with 32s and with 35s. We get snow drifts in my neighborhood and even with 35s its a challenge. You are looking at two things....You need clearance off the ground and you need to slice through the snow. The 35s will give you clearance. Pizza cutters as they mentioned are skinnier....The weight of the vehicle will push down on them to make better contact with the road and help you "cut" through the snow better. With the wider tires of the 35s you will be floating on the snow since the weight of the vehicle is spread out over more surface area. There is more of a chance of sliding with 35s. I think overall you'll be happier with the 35s.
Respectfully, you're conflating height with width.
I'm running the Kenda 35x10.50R17 pizza cutters right now.
There is also the Goodyear 275/80R17 MTR (34.4X10.50R17)
Most common 35"s by far are the 315/70r17 metric (34.5x12.50) and true 35x12.50R17
Still a lot of 35" 315/75R16s on the market. But that size is starting to disappear.
325/65r18 (35x13R18) is starting to pick up on the market.
For people who DD and tow more than they offroad.
The new Toyota TRD uses this size.
Interco Super Swampers can be had in 35" from 10.50 to 15.50 (!!!!) wide, but you will need to open your wallet extra wide too.
tshaw2009
Tony
Lebanon, MO
2011 F150 Lariat, 2018 Ford Edge Titanium
There has been a lot of good advice on here but some of the advice is only good to a point. Generally speaking, more surface contact with the pavement is better, which means wider tires are generally better in most circumstances, even in hard-packed snow and ice. If the snow you are driving on is slushy or loose, then narrower tires with lots of siping are better. I have never had any issues driving on ice (which is mostly what we get in Missouri) and snow on 35" X/T tires. People will be just fine with the Max Traction tires that come with the Sasquatch package.
Orbiter
Honda Pilot
https://www.fourwheeler.com/features/1811-skinny-vs-wide-tires-versus/
Arguments on both sides.
I am a Pizza Cutter guy. Makes for a much more enjoyable street driving experience and gives up little in the offroading I enjoy, which is dirt to rock...no mud. People think when you air down most of the footprint gain is side to side, but really its front to back. So Pizza Cutters are good there.
I also like the weight advantage moving them around, as they do get heavy, especially if you run a load E tire.
My offroad truck runs a 235/85 R16...basically a 32X9 vs the 35x12.5 that the bronco will run. a 235 85 r17 would be tempting on the stock wheels at 33X9...if they make it.
I'm looking at Toyo AT3s that come in 255/80r17, which is essentially 33x10, as a replacement for the tires on the BD or BL when worn out. They're E load rated tires though so I'm worried the ride will be stiff.
Mountain Goat
Tyler
'01 BMW 325i, '17 VW Alltrack, '20 Nissan Versa
Your best bet is 255/80R17 for a 33" pizza cutter-type tire.
Bronc-OH
New York
Jeep XK, Jeep WJ
Thanks @Incognito. I'm still kinda torn on what direction to go especially since mine will be a daily driver that also needs to handle snow, etc plus some basic trails.
I had a 76 F250 4x4 over ten years ago that had a very pizza cutter like wheel and tire setup and i kinda liked it. It also handled snow with zero issues due to the more narrow tire. Just trying to get some information together.
33x10/12.5 is a decent compromise.
Incognito
Phoenix
2017 jk
Not sure I agree with the sand comment though, a bigger foot print always wins if floatation is the goal.
I may have misunderstood the comment .
You only get flotation on sand or mud below a specific ground pressure per square inch.
That GP will be variable. Depending upon the the material and wetness.
Skinny tires aired down will act like tank treads.
They give a long contact patch vs ground displaced by the tread width. As the vehicle moves forward, you lose less momentum from the tread plowing effect vs fat tires.
The militarys of the world use pizza cutters because they are *generally* better all around. And they are not locked into one area, or type of use.
OTOH; Depending on where you live, and your uses, fat tires may be bettter.
Like rock crawling slick rock in Utah, or the bottomless swamps of Florida.
Finally, there is the looks issue.
Fat tires look bitching to most people.
A lot of people are going for the 35"s and even 37"s , just because it makes them happy.
Which is cool. The more people buy them, the cheaper they get.
evomind
All sorts of things
Really any one of the Bronco models will handle snow and basic trails.
hemiblas
Roger
Aurora, Co
17 mustang gt, 3 Wrangler JLs
When I said 35" I should have specified I meant the 315/70/17, which is what the Bronco will come with in the Sasquatch package. AGreed, you can 35s in many widths. I edited my post to clarify. Thanks again!!
Mountain Goat
Tyler
Found a Walmart 35x10.50R17s for $200, and pinned for studs, looks like a good tool for serious winter duty for those who are 'Squatched. Might swap the fender flares when you mount the winter wheels to look less silly *if you care about that*.
Now where I am, a big enough storm to justify this setup comes along every 5-10 years, but I'd love to run this setup in the Rockies.
Kenda Klever R/T KR601 LT35/10.50R17
https://www.walmart.com/ip/Kenda-Kl...wb-bYhR3FfMLkJqhS-ge4XYb4zOncXMcaAi_8EALw_wcB
