21 minutes ago
I just accepted delivery of a 2021 Ford Bronco, with the Black Diamond Trim. I have a serious problem. The MIC 2.0 removable top, that I waited 4months and 6 days for FORD to replace leaked. The leak caused electrical system failure and potentially damaged multiple electrical systems and components. I am attaching A vehicle System Health report I pulled this morning. I did not clear the DTC codes as of yet. I will be sending a copy of this report, to the National Highway Safety Administration along with a formal complaint. I am also going to post my results on this forum.
Full Vehicle System AI Inspection Report
The Report is created by TOPDON
Repair Shop
SN:988989909619
Test Time:02/19/2022 10:44
Vehicle Information
Make:USAFORD
Model:Bronco
Year:2021
VIN:1FMDE5AH0MLA68643
Odometer:0km
Vehicle Software Version:V48.75
Inspection Result
ABS (Anti-Lock Braking System) 10 problems exist
1.P05D3:86-28 Driver Mode Selection Switch #A
Range/Performance Fault
2.C1034:44-68 Parking Brake
3.C2006:74-28 Left Actuator
4.U0131:00-68 Lost Communication With Power
Steering Control Module A
5.U0138:00-28 Missing Communication With All
Terrain Control Module
6.U0151:00-68 Missing Communication With
Restraints Control Module
7.U023A:00-28 Missing Communication With Image
Processing Module #A
8.U0265:00-28 Missing Communication With Image
Processing Sensor #A
9.U0401:83-2C Data Received From ECM(Engine
Control Module)/PCM (Powertrain Control Module) A
Is Invalid
10.U3003:16-68 Battery Voltage
APIM (Accessory Protocol Interface Module) 1 problems exist
1.U0212:00-08 Missing Communication With SteeringColumn Control Module
ATCM (All Terrain Control Module) 3 problems exist
1.U011D:00-08 Missing Communication With AWD (All
Wheel Drive) Control Module
2.U0140:00-08 Missing Communication With
BCM(Body Control Module)
3.U01B7:00-08 Missing Communication With Switch
Input Module A
AWD#1 (All Wheel Drive Module) 5 problems exist
1.U0138:00-28 Missing Communication With All
2.U0151:00-28 Missing Communication With
3.U0212:00-28 Missing Communication With Steering
4.U0415:00-28 Invalid Data Received From ABS (Anti-
Lock Brake System) Control Module A
5.U1014:00-68 Invalid Internal Control Module
Monitoring Data Received From Restraints Control
Module
HVAC (Heating Ventilation Air Conditioning) 1 problems exist
1.U0452:82-08 Received Invalid Data From Restraints
Control Module
IPC (Instrument Panel Control Module) 3 problems exist
1.U0151:00-08 Missing Communication With
2.U0212:00-08 Missing Communication With Steering
3.U023A:00-08 Missing Communication With Image
IPM-A (Image Processing Module A) 4 problems exist
1.U0140:00-68 Missing Communication With
2.U2018:51-28 Control Module Software #3
3.U3000:49-28 Control Module
4.U3003:16-28 Battery Voltage
OCSM (Occupant Classification System Module) 1 problems exist1.U0100:00-28 Missing Communication With
ECM(Engine Control Module)/PCM (Powertrain
Control Module) A
PCM (Powertrain Control Module) 3 problems exist
1.U0151:00-28 Missing Communication With
2.U0212:00-28 Missing Communication With Steering
3.U0415:00-28 Invalid Data Received From ABS (Anti-
PSCM (Power Steering Control Module) 1 problems exist
1.U0415:00-28 Invalid Data Received From ABS (Anti-
RCM (Restraint Control Module) 5 problems exist
1.B00A0:68-08 Occupant Classification System
2.U0100:00-08 Missing Communication With
Control Module) A
3.U0140:00-08 Missing Communication With
4.U0154:00-08 Lost Communication With Restraints
Occupant Classification System Module A
5.U0253:00-08 Missing Communication With
SCCM (Steering Column Control Module) 5 problems exist
1.B1131:08-28 Wiper Motor Module
2.U0140:00-28 Missing Communication With
3.U0146:00-28 Lost Communication With Serial Data
Gateway A
4.U0155:00-28 Lost Communication With Instrument
Panel Cluster (IPC) Control Module
5.U023A:00-28 Missing Communication With Image
The following systems are OK:
1.ACM (Audio Control Module)
2.DDM (Driver Front Door Module)
3.GWM (Gateway Module A)4.PDM (Passenger Front Door Module)
5.RTM (Radio Transceiver Module)
6.TCU1 (Telematic Control Unit Module)
7.TRM (Trailer Module)
Garden Hose Car Wash
Leaking In The Rain
Repair Shop
SN:988989909619
Vehicle Information
Make:USAFORD
Model:Bronco
Year:2021
Odometer:0km
Inspection Result
Is Invalid
Input Module A
Module
Control Module
Control Module) A
Control Module) A
Gateway A
Leaking In The Rain
