- Feb 21, 2020
- 112
- 7,301
- 25,622
- North Texas
- SUV
- Undecided
This post is a good lead-in for...I hear you, I do and I understand your reply. However we’re making assumptions here as we don’t know what shortcuts Ford is considering and the long term impacts on performance & reliability. My warning is directed more at Ford’s lack of dedication to the brand and the fact that consumers are paying for an incomplete item. If Ford is delivering partial vehicles then let’s provide them with partial payment, with no additional fees when the missing chips arrive. Also, within a year? That’s an long time boys and girls, with ZERO faith Ford can keep they’re word on time. We’re also assuming that everything will function within necessary requirements.
Electronics 101 Primer
It is not the chips that are actually missing in any shipped/delayed vehicles. Chips are simply one element, or one component, inside of an electronic assembly, sometimes called a module, device or unit. These units are held up at the supplier awaiting the actual chips to arrive so the units can be completed and tested. Only then are the units shipped to Ford.
Dealer's will not be receiving "Chips", dealers will be receiving "Complete Modules" which contain the missing chips, for example, here is a Heated Seat Control Module for the Mustang.
An example of the actual Chips, they are the small black devices, on the green circuit board, in the open module below (three examples circled in red):
Here is an example of an acutal F-150 module being replaced. Ford ICE Mountain workers or Dealers are doing nothing more than plugging in full assemblies, similar to this.
Electronics 201 Primer
DEALERS DO NOT INSTALL CHIPS!What if.... the dealer installs the chip but it doesn't work because quality control was not able to verify it worked.
That is not how electronics are built, the chips are received at the module suppliers and then go into the fabrication process that involves multi-million dollar production equipment. Depending on the component type, surface mount, through-hole, etc, it will use different machines and processes, see examples below.
Then, during and after all of the assembly production steps, the modules are tested and reworked as needed, then and only then are the 100% functional modules shipped to Ford.
Unfortunately, automotive marketing and media types don't know how to say, as soon as our suppliers get the chips they will build the modules and ship them.
Here is an example of a SMT, surface mount component pick & place machine that inserts the components onto the circuit boards.
Then, depending on the type of components, it's time to solder, this example is a Wave solder station where the stuffed circuit boards, with through-hole components, get soldered, in that flowing, molting solder bath.
Electronics 301 Primer
Ford technician's do not install "chips", this is a specialized skill set performed by factory automation equipment or Electronic Technicians when a single one needs to be replaced.Or it could be some other small part that requires a chip that isn’t a module.
Automotive Technicians do not have the training, tools or knowledge how to do this without blowing out the chips due to static mishandling. Further, you have to have factory specialized test equipment to validate the installed chip is properly working within the module.
Some chip package styles will not even allow for manual install.
