Factory Fog Light Switch
BigMeatsBronco
Allan
2021 FE 2 door
Rear seat belt monitoring issue is what I have! And yes, I drive a 2 door...
I wonder what put out the lane centering display...?
Lane centering still works but nothing on the svreen tells me I even have it!
This is very intriguing to me...wonder which line/character changed what?
‘21OBX
90Bronco19
2022 bronco outer banks
Well this is interesting as I'm trying to turn OFF the rear seat belts ...due to my U-14 conversion I no longer need rear seat belt switches or sensors and without those parts, the idiot light stays on. I do still want the restaints indicator light to be able to work on the front.
Wonder if the as built off a 2dr F-150 would have the correct number of seat belts?
See if this would work for you.
https://www.bronco6g.com/forum/threads/how-to-disable-the-seatbelt-chime-less-than-2-minutes.42934/
WildMike
Italy
To the white/blue wire that runs to the back of the car. This wire runs down the drivers side sill under all trim. I actually grabbed it under the sill trim in the rear drivers doorway. This gave me enough wire to run it out under the hood. It’s all in this thread a big thanks to @flip for the diagrams he posted. They are live and working. Now to find out where the drl/turn signal wires are as the lights I bought have amber as well. And I want to hook them to either the turn signals , drl or both as it’s not a real bright amber.
Very precious info thanks 🙏🏻. I’m really naive at this matter
drew707
Ford Explorer
It’s likely the other change in the IPC that you made that was incorrect originally, 80, they were in the wrong spot completely let alone wrong so it probably messed with that.
drew707
Ford Explorer
For the IPC portion this should work. Not sure if it needs changed elsewhere. Only other thing I really can think of is the RCM but that’s a fickle one to mess with.
720-02-02 xxx0 xx--
WuNgUn
Ontario Canada
2 door Squatched
This is a good question... I plan on doing a rear seat delete on my truck so this info would be nice... 👍🏻
drew707
Ford Explorer
If the one I posted for him works yours should be a little different but below (for keeping rear fog)
720-02-02 xxx2 xx--
WuNgUn
Ontario Canada
2 door Squatched
@drew707 so went out to the truck just now...
"load all" for the IPC restored my backup from the file I saved, then I made the necessary changes... Viola!
Everything seems to work now.
I also went over the BCM and used the defaults you provided 👍🏻
Now I just need to get some ACTUAL lighting!
Thanks for your help...
drew707
Ford Explorer
I’m stupid like a fox!
Glad it worked
WildMike
Italy
Dang it your gonna make me go back out to the truck. Lol
I snipped it here then will take a page from ford book with hot glue and shrink wrap to seal it off. But dinner got in the way so that’s a tomorrow job.
My situation is: I have already installed a rear fog light and it’s connected to one of the auxiliary switches… Now I’m waiting for my new switch to arrive in order to modify the connections. So, if I got it right, I just need to link the rear fog wire to the white/blue wire in order to make it work with the rear fog button.?
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
This came from another thread. I did this for the driver seat but its supposed to work for all seats. Give it a shot
Ford Bronco Factory Fog Light Switch Screen Shot 2022-04-27 at 1.30.05 PM.PNG
‘21OBX
90Bronco19
In your case I would trace the wire all the way back. You do have to enable it in forscan.
WuNgUn
Ontario Canada
2 door Squatched
The modifications in BCM and IPC correct?
Drew707 posted up a table of the changes you need to make a page or two back. 2 door and 4 door are specific with regards to the IPC, FYI 👍🏻
