dcaero
Bronco OBX SAS
What's everyone's delay on the brakes? I installed this and it's about an extra second after I release the brakes, that the trailer brakes then release. It's rather annoying.
Towed the same trailer on a friends Chevy ZR2 and it had no noticeable delay.
Thoughts?
2Jeeps&PatriotX1
Denver, CO
Thoughts?
I've had a Redarc Tow Pro Elite (non-Ford version) installed on 2 different Broncos ('21 & '23) and it behaves no different than when I have the same trailer behind my f150 w/ a Ford oem factory-installed brake controller.
DoubleADuster
Aaron
Maryland
1963 Ford Thunderbird
Just finished install on this same part is it expected to light up when no trailer is installed? I don’t have trailer yet to test but right now no light shows up as test instructions state.
RoverDude
Maryland
2021 Bronco (First Edition)
Look at prior page for confirmation.
In order for it to light up it needs to see a load, 5 to 26 watts.
Good old- fashion trailer lamp will do this.
An LED tester will not have enough load / resistance.
DoubleADuster
Aaron
Maryland
Unfortunately using a trailer lamp with clips didn’t yeild any result, the controller seems dead still. Not sure next steps to troubleshoot
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
Also, without the tow package the the plug for the brake controller wiring harness (under drivers-side dash) that connects to the controller is missing.
My camper weighs around 3000 and even with my truck that is rated at 12k pounds I would not tow it at high speed very far without the trailer brake controller. If you have to stop suddenly or on a steep grade it makes a huge difference and is much safer.
Not sure if this is always the case. My 21 Badlands did not come from factory with tow package, yet the harness plug was in place by the accelerator pedal for the brake controller. Easy work.
Tonka Bronka
Duncansville
Okay, so I'm a little unclear, and I'm sorry if this seems repetitive...
I have the Factory-installed tow package. To complete my situation, and have everything I need, I still need the Brake Controller, but because I have the factory tow package, it's just wiring harness that goes in the back and there's already a dedicated spot for the knob in the front? No drilling or headache anywhere?
No.
Tonka Bronka
Duncansville
So dumb question. I have an extremely small offroad camper. Dry weight 1800 lbs. Should I connect the brake controller?
Probably. If you are doing trails, I would. One ton is still some weight pushing that Bronco and the Bronco is doing all the work. Even on the highway, could save your life. I think Ford was foolish for not including the brake controller with the tow package on a vehicle with a relatively low tow rating. When given the chance, people will do foolish things.
Grrrrrrmonster
Juston
Usa
2016 F250
@Mybbackpacker I installed the OEM controller like you. My LED only lights up when I press the control knob in. I was expecting for it to always be on when a trailer is connected. Does yours do the same?
I verified with a brake force meter that everything is wired and outputting correctly but the LED is not behaving as expected.
Hello. I know this is an old thread, and I’m not sure if this is still an issue, but I just spent the last month and a half dealing with the same exact issue and found the culprit, the wiring harness from ford that goes from the main unit to the remote head (button) was miswired. I worked with Redarc to diagnose this issue. I had them send me a new tow pro elite assembly when I changed out the cable that runs from the main unit to the remote head, The LED problem went away. Then checked the pin out on the cable that I received from Ford and it was wrong. I have reached out to ford on this issue, but have not heard anything.
rcl4668
Pacific NW
2019 Mustang Bullitt, 2023 Bronco Heritage Edition
Amazing thread, thanks for posting! As a relative towing newbie, just a question: I have the towing package installed from the factory on my 2023 Heritage 4 door with the 2.3L engine and 7-speed manual. If I ordered and installed the Bronco Trailer Brake Controller Towing Pack 1, SKU VM2DZ2C006A, ie, the console mounted brake controller package, what other specific hardware would I need to buy such as the ball thingie? Any extenders to clear the spare tire? Thanks and again sorry for the newbie question!
Defyfate11
Jaime
Clovis, CA
2020 Camry TRD
Can you clarify, what exactly is needed to fix the miswired issue??? Different cable? The remote head is the (dial) correct?
dcaero
Bronco OBX SAS
Yes any follow-up would be great. Have you figured out from Ford how to re-wire?
dcaero
Bronco OBX SAS
Does anyone know how to change between manual and proportional mode? I seem to be stuck in manual mode, and no matter how many times I follow the instructions to switch to proportional nothing seems to change.
Ford Bronco Factory Trailer Brake Controller installation feedback Screenshot_2024-05-21-07-12-38-90_e2d5b3f32b79de1d45acd1fad96fbb0f~2
dcaero
Bronco OBX SAS
bump, anyone?
Defyfate11
Jaime
Clovis, CA
2020 Camry TRD
bump, anyone?
Probably related to the miswiring of Ford. Once someone actually provides details on how to correct it, I’m just fine with how it works right now, which is probably manual mode. I set it at “2” and make micro adjustments when needed. Going to a 3 is too aggressive.
