Treeza61
Richard
2017 F250, 2019 4Runner TRD Pro, 2013 FJ
I’m not seeing a big difference between 33s and the Sasquatch 35s.
Do the two with 33”s have the high clearance suspension?
makatron
Isaac
Dominican Republic
Isuzu D-Max 3.0L 4-cylinder diesel
Yeah the whole point of building a test rig is, *coughs profusely*, test them.
BAUS67
redneck
Central PA
We got some trash talking lol, aside from that though they got pics of the trail rash! As to be expected when you’re thrashing rocks on the rubicon in a stock ride! Now imagine pros who wheels 24/7 and rank rigged up bronco with all the fixings. I bet it come out strong!!
Brian McCormick !!?? last I heard he was not doing to good, looks like he must be feeling better.(y)(y)
Kane
JC
19 Tundra, 07 Jeep Rubicon
There are a few things that are clear to me from watching all the videos and seeing all the photos:
1. Both the 2 door and 4 door look cool, way better than the Jeeps.
2. The Bronco is a very capable vehicle.
3. The Bronco is not as trail focused as the Jeep Wrangler Rubicon but it isn't horribly far off.
4. The Bronco will handle daily driving MUCH better then the aforementioned Jeep.
5. The Bronco will hold its own for most people who go off road.
6. Don't consider it an extreme rock crawler or test the entry, exit or break over angles too much and you'll be VERY happy.
7. Some of the new tech is awesome!!!!!!! (cameras in the tire well could allow drivers to do things they couldn't do before without a spotter...but how do you keep them clean????).
8. The biggest limiting factor for the Bronco is articulation. This is a result of the IFS. The IFS is also what will make you so much more happy on a day to day basis when you're not off road. It also will make you more happy in 4 wheel high on sand or dirt roads or whoops.
9. Without doing some serious cutting or fender replacements, or limiting articulation, you're not putting anything above 35's on a Bronco. That said, someone will cut one up I am sure. FrankenBronco.
From the looks of things this vehicle will be as capable as the Toyota FJ40's were, but with a lot of new tech to make the experience easier. Last thought, one of the posters did find the exact right area on the Rubicon trail and I have taken a stock Rubicon (2010 4 door) through that section on that line with no damage. I am on ok driver, not great, the only real difference that allowed the stock Rubicon to make it was slightly more body clearance and a lot more articulation to keep all four tires pulling. The jeep is made for crawling and because of this it doesn't handle some other things all that well, the Bronco is made to handle more varied conditions, all with solid performance.
All of the above being said, I hate driving my Jeep on the road. Sure my current one is now heavily modified, but even when it was stock, anything over 40 minutes was tiresome. I seriously doubt the Bronco will have those issues.
Everything is about trade offs.
SVR
UAE
2020 Wrangler JL
IARubicon
Iowa
2018 Jeep Wrangler Unlimited Rubicon
While this test and the discussion comparing the new Bronco to the Wrangler is fair, given the trim and option levels, the Bronco is clearly meant as an all-around off-roader. The Jeep Wrangler Rubicon (which I own) is designed specifically for rock crawling. The Rubicon SHOULD do better on the Rubicon Trail than the Bronco. The Bronco just has to hold its own in this environment to be competitive. But let’s be honest - it’s sort of like comparing an MMA fighter to a boxer in a boxing ring... There is much more to off-roading than rock crawling. I’m looking forward to seeing the Bronco in other environments.
And regarding the SFA vs IFS, I won’t argue with those who have more experience, but just note: the last generation of military Jeeps which served from the Vietnam era until the early 1990’s (the M151, designed by Ford incidentally!) had independent front suspension. So to those who say “real” Jeeps never had IFS, REAL Jeeps have had them since Vietnam.
BAUS67
redneck
Central PA
BAUS67
redneck
Central PA
No I don't personally...we have mutual friends on FB. That's how I saw what he originally said! One of the mutual friends made a comment!
Just curious, I knew him back in the 90's, we both raced Fox bodies. His family used to have a Ford dealership, still have a sxs/snowmobile dealership.
618TRVLWILD
Ashley
Southern Illinois
Big Bend Sasquatch 2D
Heck yeah that's awesome!! I bet he's fun to wheel with!!
BAUS67
redneck
Central PA
Ryuk
PA
2021 Ford Ranger, 2023 Ford F-150
So what is the body damage he is talking about?
BAUS67
redneck
Central PA
Ryuk
PA
Wow, so after looking at those pics, my only conclusion is......
McCormick is an idiot
I've seen people do more damage on a flat dirt trail because they have misjudged a turn around a tree.
