I read that just now and see nothing different than the 2022 manual. Can you help me out and tell me where you’re finding a new procedure in the 2023 manual that’s different than previous years?Reference the 2023 bronco owners manual.
It’s online
it shows the new procedure
https://www.fordservicecontent.com/...A&div=f&vFilteringEnabled=False&buildtype=webI read that just now and see nothing different than the 2022 manual. Can you help me out and tell me where you’re finding a new procedure in the 2023 manual that’s different than previous years?
No not “none” just not boosted.So with EBB not active , we are getting no braking with rv brkae pushing on peddle ? Thanks in advance
You need an auxiliary brake system that’ll work without boost being active on the tow vehicle. There are a few options discussed throughout this thread. I’ve got an Air Force One and it works fine as long as it’s set up properly and as mentioned there are others that’ll work.So with EBB not active , we are getting no braking with rv brkae pushing on peddle ? Thanks in advance
what to I tell installer who instlaled the Air Force 1 I have , anything highlights would be appreciateYou need an auxiliary brake system that’ll work without boost being active on the tow vehicle. There are a few options discussed throughout this thread. I’ve got an Air Force One and it works fine as long as it’s set up properly and as mentioned there are others that’ll work.
I had my installer call the guys at Demco and they walked him through the proper setup for the Bronco. I talked to the guys at Demco and they said they’d do this since they’re aware of what needs to be done. I’d be lieing if I told you I was sure of how they set it up.what to I tell installer who instlaled the Air Force 1 I have , anything highlights would be appreciate
It’s in the manual for the AF1. You essentially fully cap the exhaust vent to direct max pressure to the petal for no boost situations.what to I tell installer who instlaled the Air Force 1 I have , anything highlights would be appreciate
Have you been in tow mode to check to see if you have the update?I did get that 22-PU1010-MIL-LT a couple weeks ago.
I also got a much larger update 22-PU0925-HAZ-FLH on Friday that also had no defintion, but now has one on the NHTSA site:
2021-2022MY Bronco (BCM)
22-PU0925-HAZ-FLH
Software Updates Have Been Made. A few small adjustments were made to restore your trailer light check feature to include the vehicle license plate lamps when the Trailer Light Check is operating.
So, it pertains to towing, but only managing the license plate lighting.
