Can you purchase the Ford Factory 4-Door Fuel Tank Skid Plate as a stand-alone? If so, does anyone have the part number?
I was hoping that it would be less expensive than aftermarket and from what I have seen, they work pretty well.
I have found the full set as low as $675 and the fuel skid at $545.For the same price as just the fuel you can get the whole set.
Bronco 4Dr 2021-2023 Steel Full Body Bash Plate for vehicles with Modular Front Bumper | FordUSAccessories
That's the thing, I have heard nothing but good things about the factory fuel tank skid. I'm not a serious rock crawler by any stretch but we do have a lot of pointy ones where I bird hunt. I am going aftermarket for the trans and T=case plates.Something to consider is that most (all?) aftermarket fuel tank skids are two piece units. This means you will have an easier time bending those skids (where the pieces meet) into the fuel tank when you beat on them. There are members here who have really beat on their skid plates (@Snacktime is a great example - check his skid plate thread(s) for additional info - https://www.bronco6g.com/forum/threads/skid-plates-discussion-round-two.71152/) and still recommend the factory fuel skid over the aftermarket for its one piece design
But if you aren’t planning on doing a lot of rock crawling, you probably don’t care about that
Thanks for the heads-up!When you order from Ford Accessories, you can get it delivered to any Ford dealership for free. Once you order is placed, Ford Accessories will reach out to that dealership to see if they currently have it in stock, if so you will get it sooner, if not Ford will send. Also, I used Ford Pass points and the 20% discount code. Got the full set for around 500. Even without pass points you can get the set for around 710 after taxes.
