How early would a reservation need to be to safely assume there would be no effect from commodity constraints?
Runningwaters
Jeep
Say someone wants every option listed as constrained (but not late availability or MY22).
What's a good time cutoff estimate on the first night for reservations that would be safe to assume the reservation holder will not be affected by any commodity constraints?
Macjr
Martin
Northern NY
Toyota Tacoma TRD Offroad, 2020 Volvo xc40 RDesign
I have zero clue but perhaps some on here know better… I have no idea if ill get mine early or late in fall..I’m 1 of 14 allocated to dealer with a 7/19 reservation who knows since I have one of the deadly options which can cause delays..
-BD 4cdoor
-Sas
-2.3
-Mid
-Tow
ResidualGenius
Zach
Denver
use the search, this had been brought up numerous times
Gamecock
Then what’s the answer?
I’m sure he’s familiar with a search feature...and you saw the thread title and still decided to click on it.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
There’s really no way to even guess because we have no idea what the tightest constraint is, how many of those parts they have, or the breakdown of when Bronco reservation holders around the country reserved and what their build is.
For instance, you would have to find out that they only have 100 2.7 motors... and that the 100th person in North America to order a 2.7 by reservation time stamp reserved at 4:37 am...
Then you’d get your answer.
papsblue
Nick
Colorado Springs
21 Badlands
The search feature on this forum is god awful. You search for Sasquatch and it comes up with results for cup holders instead.
I've used google search adding " , site:broncog6g.com" at the end of whatever I'm looking for.. sometimes gives better results
Desert_6G
Phoenix, AZ
Ranger
Earlier the better. Anything past week 1, I'd say forget about it. Most of the reservations were made in just the first few days of reveal.
ResidualGenius
Zach
Denver
Unless you know the exact number of parts available as @ZackDanger said and then know how many ordered that combination its not something that will be known until Orders close in March and build dates are given out in May as has been mentioned.
HoosierDaddy
I'll tell you sometime in May. Lol.
Right about the time you think you have it figured out later this spring, a tornado will strike which ever widget plant and delay all 4x4 builds by 3 months minimum.
Thankfully, nobody will get hurt.
swooshdave
Portland, Oregon
Mustang
Reservation date is only one factor. Top factor is did you convert to an order. Next is final dealer allocation. Which isn’t set yet. Then it comes down to scheduling. I have a feeling there will be a lot of bent noses when people with early reservations start seeing people with later reservations driving off the lots. You want to be the first kid on the block? Order a base with no options. I bet that gets built first.
J_Meh_Cray_D
Jeffrey
2017 Silverado Crew Cab
It’s not a linear answer. For instance, I reserved in the first 3 hours... so if Lux is the only commodity constrained item on my spec, maybe I have a good chance of immediate production.
But if you have several late availability items... assume Ford will make the best decision for Ford. Why make one vehicle with three commodity constrained items when they could make three vehicles, each with one commodity constrained item?
It depends on their true limiting factors. Then on Ford’s internal logic on how best to employ those resources to manufacture the most Broncos up front. Just my guess
Bronco4lyfe85
William
2019 Challenger Scat Pack
The first 12,426 will not be affected, after that you’re screwed.
