I got oil and a filter, just making 100% sure no other parts will become necessary since I don't have another vehicle to get to the store in.
You haven’t told us which engine you have.I got oil and a filter, just making 100% sure no other parts will become necessary since I don't have another vehicle to get to the store in.
Ah figured it wouldn't matter, it's the 2.7l. Looks like plug and seal should be reusable unless it's damaged somehowYou haven’t told us which engine you have.
Nice...
Bwahahaha! Have fun with the drain plug on your 2.7LAh figured it wouldn't matter, it's the 2.7l. Looks like plug and seal should be reusable unless it's damaged somehow
Amazon.com: 6PCS Dsnaduo Oil Drain Plug Fit For Ford F150 2015 2016 2017 2018 2019 2020 2021 Lincoln MKZ Replace KX6Z-6730-B, KX6Z6730B, FT4Z-6730-A, FT4Z6730A, BC3Z6730A, BC3Z6730B : AutomotiveAh figured it wouldn't matter, it's the 2.7l. Looks like plug and seal should be reusable unless it's damaged somehow
Thanks, just ordered the plugs.Amazon.com: 6PCS Dsnaduo Oil Drain Plug Fit For Ford F150 2015 2016 2017 2018 2019 2020 2021 Lincoln MKZ Replace KX6Z-6730-B, KX6Z6730B, FT4Z-6730-A, FT4Z6730A, BC3Z6730A, BC3Z6730B : Automotive
This is the best value, last month I got the 8pc which was cheaper per but not available now.
The part that you will/may damage is the ears. Very easy to do. The ear tabs just keep the plug from rotating out, a safety or secondary feature, one tab is all you need. I'm a seasoned mechanic and was trying to be careful and still popped off a tab.
The wife's 3.0eb uses the same filter and plug, I bought in bulk for a lower per price and the filters do not seem to be all that common, strange since they have been used for 7 years now in the F150.
The key to not making a mess is to twist the plug out partially and keep it blocking the stream till the flow subsides. If you do it right no oil will be spilled or much on your fingers.
Recommend adding this drain plug...I got oil and a filter, just making 100% sure no other parts will become necessary since I don't have another vehicle to get to the store in.
