Installed a hitch... What gear should I be towing in?
Jkabara
Joseph
Belleville
2021 bronco
I just installed a hitch on my 2021 bronco. What gear should I be towing in?? I know in my f150 you should not tow in overdrive thanks
Taltyman
Paul
Forney tx
Jeep wrangler Rubicon, Ford F350, Braptor
Don't have my bronco yet but for me the answer is "it depends" . If it is a light trailer with a light load and on level ground then I leave overdrive on. If it is a heavier load then I decide based again on the situation. If I'm going up and down hills, etc then overdrive goes off. If unsure then overdrive off is safest.
Jkabara
Joseph
Belleville
2021 bronco
It’s a 10 speed transmission how do you turn off overdrive
Riverat
Adam
Ram 3500
Really depends on how fast you are towing.
66Fan
Tim
IL
2022 Wildtrak
IIRC - The top three - 8th, 9th and 10th are all overdrive.
If you stay within stated capacities, tow in D.
da_jokker
Jeep Wrangler JKUR
I'm not the expert, but if it were me I would look into two options...
1) assuming you have an automatic, I've always let my transmissions just do their thing... Unless I notice it constantly downshifting. So if it won't stay in OD, then I would manually put it in the lower gear and force it to stay there. Constant shifting builds up too much heat.
2) Broncos that come with towing have a towing mode. I don't know what that does, but maybe that something that can be enabled through Forscan.
Jkabara
Joseph
Belleville
2021 bronco
Sounds like nobody knows 😂
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
didn't read the whole thread, but I usually tow in whatever gear I'm wearing - shoes, jeans, t shirt, maybe a jacket if it's cold. ;)
bronco_billy
Indy
Crown Vic
The Setup: 4 door BB, 4.27 gears, 2.7. Stock tires and rims and factory tow package. Towing a trailer that weighs approximately 3,400lbs. 93 octane. Normal Goat Mode.
The Strategy: driving around town, stop and go traffic put it in drive and let the Bronco figure it out. On the interstate put it in manual mode. Set the cruise at 67 mph. (70 mph zone) when the boost gets over single digits, manual downshift. Adjust up or down depending on the terrain.
I was traveling on flat and hilly terrain as well as some mountainous spots. I have used this strategy on a couple of trips. Just got back and averaged 14.8 mpg. The lowest gear I ran was 7th a few times. Spent most of my time between 8 and 9. Ran 10 mostly on down hill runs.
Hope this helps! Cheers!
KABQ
Aaron
Albuquerque, NM
From a stop, use first. As you accelerate, shift to second, third, etc. as dictated by your speed. When decelerating, downshift to aid in braking. Once stopped, use first again.
/S
I don't understand the question. Which gear you use is dictated entirely by speed and situation. It isn't like you'd just use one gear like you seem to be asking ("I only tow in third gear" would be stupid).
dgorsett
colorado
F250, Mustang, Explorer
With the AT On flattish country I'd say normal. But in the hills or near capacity like the op I'd say sport, it holds the gears longer and downshifts quicker going up or down hill..
AZ_Liberty
2007 Expedition
4th is drive. Both 5 and 6 are overdrive.
Um... unless you bought an automatic for some reason, in which case 8, 9 and 10 are all overdrive gears. I'd lock out at lease 9 and 10.
