- Thread starter
- #1
I am upgrading the bronco tin can speakers with the kicker KS series, front rare, and adding the JL Audio Stealth box sub in the dummy speakerbox location. The issue I’m having is my muse way six channel amplifier that I’m using to power. All the speakers is too large to get mounted to the stealth box so I am contemplating on installing it in the hidden compartment underneath the rear floor. However, the power cable and the cables that I ordered from Plug and play kits.com are half inch diameter and too thick to run under floor pad. So now I am contemplating running all three half-inch wires underneath the vehicle following the wire harness that is mounted alongside the chassis. I am using a flexible split loomand taping it with the heat resistant fabric tape and zipping it to the existing wire harness. Do you guys see any major issues with this set up? I think it will work, but trying to make sure so any recommendations
