- Jul 14, 2020
- 125
- 6,164
- 7,042
- California
- Jeep Wrangler JKUR
- Wildtrak
So the factory base system has an EQ on the front and rear channels, along with an aggressive crossover on the rear channels. Currently if someone wants to add a sub, they have to get signal from the front speakers. This Forscan change would allow you to get that from the rear speaker wires.
Also, this allows you to get full range (bass) to the rear speaker pods, this will not help the OEM speakers much as they also have a built in high pass filter. However an aftermarket speaker may not, and with this you should get fuller sound even with the factory speakers. With that said, a good system does need some DSP work to deal with the oddities of the automotive listening environment.
You had me at "allows you to get full range from the rear speakers"....will make wiring up my aftermarket amp so much easier!
One more question... You know, for my 10 year old ..... Doing this change to flatten the signal, does it still allow me standard Bass/Treble and Fade controlls?
