internationlriders
Josh
Alberta Canada
2021 Bronco Badlands
So I guess I'm still waiting for a diff drop bracket to come to market or else find a shop to fab one up. 🙁
Just_Jim
Just_Jim
Minnesota
2021 Big Bend
Thanks to a stomach bug and copious amounts of Pepto 😳, I was able to take the truck out of commission the last couple days and finally install the extreme clearance kit body mounts.
Ford Bronco King 2.5 Bronco kit installed PXL_20221024_052725407
Ford Bronco King 2.5 Bronco kit installed PXL_20221024_052748108
These really clean up the chassis behind the front bumper, and open up a world of protected space for the reservoirs.
My stomach and my neck said "enough fun" for tonight, so the last 4 holes to mount the reservoir clamps will have to wait until tomorrow.
Just_Jim
Just_Jim
Minnesota
2021 Big Bend
All that's left is to trim the fender liners and decide if I'm going to put a hose clamp on the lines to anchor them to the frame.
Ford Bronco King 2.5 Bronco kit installed PXL_20221024_210028483
Ford Bronco King 2.5 Bronco kit installed PXL_20221024_210012790
As you can see, there's nothing between the bottom of the bumper and the wheel, so there's that little bit extra approach clearance for rocks.
Aztec1382
Sam
F350
Nice
Did you just screw them into the body?
I had to improvise as well since i had the
Same clearance kit
Ended up ordering some universal tube clamps and welding them
Ford Bronco King 2.5 Bronco kit installed C1C0A6A6-5A8E-4A00-829A-EC8AC5CBED54
Aztec1382
Sam
F350
Finally got my 37’s mounted last night and took measurements today. If I’ve got time this weekend, I’ll put it on the lift and adjust the fronts to level it up with the rear.
Rear:
All these king shocks must be set differently from the manufacturer
Mine base sas manual
Before
Rear
Before 41.5. After 43.5
Front 39.5 after 43.5
currently sits level
But will probably have to raise the rear after the tire carrier and rear tire go back on.
Ford Bronco King 2.5 Bronco kit installed 4DC64926-B3BC-4849-8ADF-071CAE34EF53
Just_Jim
Just_Jim
Minnesota
2021 Big Bend
Nice
I bolted through the core support. There's an opening right above where the clamps are, so I was able to drop the screws in from above and tighten.
Were I to do it again, I'd put thread-certs into the core support and use an intermediate mounting plate to bolt the clamps onto and then bolt to the truck. There's not much room to swing a wrench and it's down in a hole.
Just_Jim
Just_Jim
Minnesota
2021 Big Bend
Came out nice
Thanks!
While I was at it, I started working on my own hidden winch mount, but discovered I need a few more chunks of steel first. I also corrected the odd angle the front bumper was sitting, so it was pretty productive despite not hitting all my goals.
Johnny Rebel
LA
2021 2D Big Bend, 2022 Bronco Raptor
Before
Rear
Nice ride! Are those Baja LP6’s on the front bumper? Got a set I need to install but haven’t had the time lately to get to it.
I increased the preload on my fronts from 0 threads (as delivered) to 4-5 threads (5 full turns) after I took those pics. It raised the front 1” and was level. Then I realized I didn’t have my spare mounted……. So now it sits slightly front-high. Need to get back in the shop and level it out when I’ve got some time. Pic below.
Also, I don’t know about anyone else, but the passenger side front shock on mine can’t be adjusted without taking it off the truck unless you’ve got a couple of different sizes of short spanner wrenches. The remote res fitting gets in the way of inserting the adjuster bar into the collar after a half turn…..
Just throwing that out there in case somebody else reads this before they go to adjust theirs and runs into the same problem.
Ford Bronco King 2.5 Bronco kit installed 82926A8D-7664-4DC2-A5CA-6668C6DA4623
Ford Bronco King 2.5 Bronco kit installed AE5D5BFF-FBAB-4993-B41E-29A8BC330721
Aztec1382
Sam
F350
Thanks for the heads up in the spanners
They are baja lp9s
what is everyone running for the rear links
most of the ones i have found are not adjustable.
core 4x4 seems like the only option
Evolkidbell
Northern Colorado
1966 Bronco, 2013 F-150
They are baja lp9s
I have a set of the Camburg Non-Adjustable lower links. Yet to install them due to the rear passenger bolt issue.
Poly Performance is about to release theirs. Adjustable length.
Johnny Rebel
LA
I installed a set of the Camburg lowers when i installed the Kings.
Is the issue you mentioned related to the difficulty removing the upper passenger bolt or is there something else? I removed the nut, slid the bolt over, then cut the head off with a recip saw. As long as you’re patient it’s not too bad.
Aztec1382
Sam
F350
spoke to synergy which owns poly performance
They said they were releasing bronco parts but were another 7 months to a year out.
i ended up ordering with rock jock
