- Rick
- Sep 9, 2020
- 1
- 351
- 953
- Rochester, NY
- 2013 F150 STX 5.0L, 1999 Mustang Cobra
- Badlands
- #16
In this case, the pins serve double-duty as guides for the casing end cap. After I had removed that (which I was able remove by working split line around the outer diameter with a pry bar), they were sticking out of the diff housing about a 1/2", which was enough to clamp into a vice and twist and twist and pull. They were also sticking in to casing a good inch or so. They fought, but I won...Excellent write-up! Thanks for taking the time to post it.
Can the SPIROL coiled spring pins that are retaining the half pins be removed with a drift punch? If not, how the hell did you get them out?
