Rocketeer Rick
Rocketeer Rick
Rick
Rochester, NY
2013 F150 STX 5.0L, 1999 Mustang Cobra
Excellent write-up! Thanks for taking the time to post it. 👍
Can the SPIROL coiled spring pins that are retaining the half pins be removed with a drift punch? If not, how the hell did you get them out? 🤔
In this case, the pins serve double-duty as guides for the casing end cap. After I had removed that (which I was able remove by working split line around the outer diameter with a pry bar), they were sticking out of the diff housing about a 1/2", which was enough to clamp into a vice and twist and twist and pull. They were also sticking in to casing a good inch or so. They fought, but I won...
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
Ahh, that makes sense. I didn’t realize they were that long and serving double-duty. Too long to simply drive down and out through the exit hole. Thanks! 👍
Rocketeer Rick
Rocketeer Rick
Rick
Rochester, NY
No, that would've been the better answer - if they had an exit hole. But they were in blind holes, which seems to be more and more common these days.
DirtyGSer
Jay
Massachusetts
Jeep Compass
Fantastic technical writeup and pictures!! Better than many who do tech-pubs for a living!!
Thanks
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Thanks
Well, it is what he does for a living I think.
Rocketeer Rick
Rocketeer Rick
Rick
Rochester, NY
Thanks
Technical writing, no, that's not it specifically. I mean sometimes its part of the job, but I'm a development/application engineer that pretty much specializes in differentials, axles, drive systems. So, I'm more on the design/development side of things. In this case, I happened to get a hold of one of these for benchmarking study; what I posted was adapted from my own report on it. But I'm glad you guys dig it.
kodiakisland
Arkansas
Yeah, what I meant was you tear into those for a living, not like one of us who just take things apart to see what's in them. I'm pretty good at the tear down, not so much at the rebuild.
Hope you get a M190 and 210. Really interested in what you find on the M190 and whether it's worth putting more money into it.
Rocketeer Rick
Rocketeer Rick
Rick
Rochester, NY
The question will come down to how readily you can get the right gears for it are. Most of the ratios that Ford picked for these vehicles are unusual, with the exception of the 3.73s. But the Broncos with 4.70 only come with M210s up front, so no issue there. As I understand it, people with 3.73 gears can get them from the JL parts bin. But the 4.27 or 4.46 gears might be tougher to find. If they don't become available, then the owner would have to choose something that is more common, but have to regear the rear axle as well. At that point, you're probably better buying the 4.46 M210 and swapping, at least if you have a BD or BB that have 4.46 open front diffs.
FordOwner
SoCal
a few
I'm not sure if that's true. I know Dana tried to acquire GKN Driveline, but I thought that deal fell apart? Guess I'm not sure...
They're both certainly on my radar. But priority has been to get the M220 done first, since that's used very widely. I'm hoping that the 210 is similar internally (since they refer to both as "Dana 44" models) and I won't have to change much, but we'll see. I plan to get a hold of one of the M210 crate axles as soon as they're actually in stock somewhere. The M190 is also on the radar, but the fact that folks have swap R&P sets to install makes it less appealing...
Leave it to engineers, right?!
Looks like the GKN and Dana agreement did fall through and GKN was bought out by Melrose. Not that I knew any of this before today, just hit the old Googleverse... https://www.rubbernews.com/article/20180329/NEWS/180329930/gkn-shareholders-choose-melrose-over-dana
https://www.gknautomotive.com/en/company/our-heritage/
Anyway, this was a cool, in depth look at the e-locker. Thank you for posting this OP!
iamcris
Cristian
Lakewood, WA
21 Bronco Badlands
Your photos and write up are outstanding. As soon as I read "expensive" I puckered. As soon as I read about the towers I relaxed. Thank you for not leaving that important information as a cliffhanger.
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
This is a great post, thanks for doing it.
I have a non-sas Base and have always thought that some day I would find a 4.46 with locking diff from a junkyard or salvage Badlands and just do a full axle swap. But this part you wrote makes it sounds like it wouldn't be as simple as just routing 12V to engage it:
" But on a high level, the control module sends about 5 amps or so to the coil to activate the lock. It holds that current for a minute or so to make sure it has time to engage, then cuts the current down to maybe 2 amps to help hold the lock, but without drawing enough power to overheat the coil. When you (or the ECU) decide to disengage, it cuts the power, and the return spring pops the lock plate out of mesh just as soon as it isn’t torque bound. "
Rocketeer Rick
Rocketeer Rick
Rick
Rochester, NY
Well, in principle, that would work. That's why I make the comment about doing just that as a field fix if the control module takes a dump. That assumes, of course, the coil was designed to be fed 12V and isn't stepped down to 5V or something. Without knowing the draw of the coil, I can't really calculate that.
That aside, Ford put a bit more sophistication into the control strategy then simply turning on or off. Part of this is to put limits on when the lock can be engaged or if stays engaged (ie speed limitations, not to severe of a wheel speed difference, etc) for safety reasons, part of it is to make sure that the coil itself is protected from overheating.
If the magnet is left to draw full current for an extended period of time, it could get too hot and get damaged as a result. So they step down the power after it locks to prevent that. Once its engaged, it only needs a small amount of current to stay locked. But with that said, I think that if you manually wired it and were smart about how you used it (ie don't leave it locked when not needed), you could still get away with it.
BottleShark
TJ
East Texas
Nautilus, Samurai, 12v Dodge, Fiero, Karma Ghia
Who's the nerd who decided "thrust washer" was politically incorrect?😂
Thanks, now every time i use or hear "thrust washer", I'll think of my wife.... lol
lakesinai
Charleston SC
This is actually the first thread I've started here. In case anyone is interested, I put together this look at workings of the M220 e-locking differential. I got my hands on a sample part through work for development purposes. I thought it would be interesting to show it in depth, going through a tear-down of the assembly.
So here’s the differential as it stands complete, as you might remove it from the axle (bearings removed):
The wiring connection goes into the axle casing above and to the right of the differential, there’s a pass-through connector that it plugs into from the inside.
At the “top” of the assembly (in our business, we consider the flange-end of the unit to be the bottom) sits the locking solenoid. This is an electromagnet and has a sliding armature inside it that will push on a dog clutch mechanism inside the diff casing when activated.
The solenoid itself is easy to remove, in fact, the Ford service manual for the axle shows that you remove the solenoid when you replace the differential. It will lift off of the top end once the journal bearing is removed; the bearing is basically the retainer for it. With the solenoid removed, there is a thrust washer and we’d call an “apply plate” remaining underneath where it sat. You can see those below:
The apply plate snaps onto the differential’s locking plate with little spring tabs. The apply plate looks like this:
Its just a .06” thick steel stamping, but it serves the purpose of connecting the solenoid (which is fixed from rotation inside the axle – otherwise the wiring would wrap up) and the lock plate inside the diff which, of course, spins at road speed. The plastic thrust washer that sits above it provides a low friction sliding surface to translate the motion of the solenoid armature to the apply plate.
So, if we take off those parts, we’re left with just the differential itself. Fundamentally, it’s a basic open differential design. However, it has 4 pinion gears (sometimes called “spider” gears) to connect the output gears to the casing. Typical open diffs have 2 pinion gears, so using 4 effectively doubles the strength of the gearing itself by spreading out the load across twice as many teeth at any given moment. So that’s a nice feature.
It might be nice functionally, but doing that adds a bit of complication (read: cost) to the design. For starters, the differential’s casing has to be made from 2 pieces for assembly purposes. Most open diff casings are 1-piece (and thus dirt cheap to make), and all the gears can be loaded through the holes in the sides.
In this design, the casing is split through the ring gear flange and relies on the ring gear bolts to hold it all together when assembled. This is the end cap piece after removal:
Removing that exposes the bevel gearing:
And the by lifting out the flange-end output gear, you can see the 4 pinions riding on their cross pins.
Having 4 pinions requires a more complicated cross pin – you can see it has one full-length pin, and two “half” pins, which are guided in a cross-drilled hole through the full pin. So, you can see where the part and assembly costs are increased.
If we further remove the cross pins (BTW, the half pins are retained with a spirol pin that’s driven into the casing from the flange end, you can see the holes they go in near the “1” and “3” marked on the casing), you can see into the housing with the remaining output gear in place. Removing these pins is a pain in the butt, which I am not detailing here. Here we see inside the casing with the pinions removed:
This gear is part of the lock device, but the lock plate that is operated by the solenoid is underneath it:
Also visible in this photo is the return spring, which holds the lock plate away from side gear when not in use. This is just a simple wave spring.
And then, finally, removing the lock plate from the assembly leaves an empty diff housing.
Note the five slots in the end of the housing, these are important in a couple of ways, which I’ll return to. The lock mechanism itself is about as dirt-simple as it could be. It uses what is called a “face clutch”, which has sort of like spline teeth that run radially outward instead of being parallel along the sides of a shaft. These “dog” teeth allow a lot of contact surface when engaged, with the benefit of only having slide a few millimeters to achieve a full engagement.
You could do the same thing with a sliding collar over a conventional spline, but it would have to translate over a greater length to have good strength. The picture to the left shows the face clutch in the relaxed position, to the right is engaged.
The actual teeth on the face clutch have a slight angle to them, so that they can drop into engagement easily when commanded. They also allow the spring to quickly pop them back out when the lock is turned off.
Of course, making it easier to pop out adds a concern about coming out when you don’t want it to. This is where the slots I referred to before have a role.
The slots work in conjunction with the protrusions, or what I call “towers” on the back side of the lock plate. The primary function of these towers is to create a torque flow path from the casing to the lock plate, and then on to the output gear when the lock is used. Normally, torque in a differential flow from the ring gear to the casing, then through the cross pin to pinion gears. The pinion gears transfer it to the output gears, and on out to the axle shafts.
However, when you lock the unit, you create an alternate torque flow, where it flows from the case to the lock plate, and to one output gear. It then is transferred to the other output gear through the pinions. The towers engage in the slots in the casing to allow that transfer, like a kind of keyway.
The towers and slots have a secondary function, which prevents the lock plate from accidentally popping out of engagement with the lock output gear. Note the shape of the towers – they have a 15-degree taper to the sides, which is match by a taper in the slots.
This is a rather clever bit of engineering - by having a taper angle to them, when any torque is applied to the differential at all in the locked mode, the tapers act as a sort of wedge cam. The load on the taper forces the lock plate to thrust into the mating clutch face on the gear; it can’t back out until the load is removed.
This also means that the solenoid doesn’t have to try to prevent unintended disengagement. It’s held in place mechanically.
Here is more detail of the components – to the right, gears laid out after removal from the housing. Below is all of the assembly’s parts spread out.
At the bottom of the page, we have the solenoid up close. The brown ring on the underside of it is the armature I mentioned above. It slides inside of the solenoid when activated, moving a total of about 3mm from the relaxed to engaged positions. As I mentioned before, the solenoid itself is not a rotating part. It has a retaining bracket that is held in place by the bearing cap bolts, which in turn keys onto the pin you can see in the 7:00 position in the photo at the bottom right. The solenoid has a molded bushing on its inside diameter, which allows it to ride on the differential casing while the casing spins inside it. Note that the plastic bushing on this particular part was damaged in shipping (Ford's service part group could do a better job packaging)...
I am not going to get into details of how the computer controls work for this, as that’s above my pay grade. But on a high level, the control module sends about 5 amps or so to the coil to activate the lock. It holds that current for a minute or so to make sure it has time to engage, then cuts the current down to maybe 2 amps to help hold the lock, but without drawing enough power to overheat the coil. When you (or the ECU) decide to disengage, it cuts the power, and the return spring pops the lock plate out of mesh just as soon as it isn’t torque bound. Overall, this whole system is pretty simple from an engineering perspective - very effective and reliable. There is little to fail. For the lock to physically break, you’d have to either shear the dog teeth off or the towers off.
I’ve run through the math; those features both have about a 30% safety factor above the shear strength of the axle shaft itself. And that, BTW, assumes that only 40% of the dog teeth actually carry significant load, and that only 3 of the 5 towers are pulling their weight. Past that, the electromagnet can’t really fail unless a wire is cut. The solenoid mechanism really must work if current is applied the to the coil, there’s little choice from a physics perspective. The only other failure mode is then if the ECU that operates takes a dump. But that could be field fixed by rewiring the solenoid to a simple switch and relay.
Then consider that a design like this will essentially drop into the existing axle packaging. Aside from a wiring port, there are no extra pieces of hardware required, no plumbing to run, no servos or shift motors to mount to make it work. That’s why most truck manufacturers have adopted this or something similar. The locking differential in the F-150 is essentially the same design, though there are differences in how it’s packaged.
Although the M220 axle is made by Dana, I think that this e-locker is sourced from GKN. The tapered tower design is their patent feature. Ford also buys the F-150 lockers from GKN as well. Dana uses Eaton e-lockers in their aftermarket Jeep axle assemblies, so it could be that Ford directed them use the GKN design here. The Eaton design has a similar operating principle but relies on sliding pins into a lock plate instead of the face clutch as I recall. There are a lot of different variations on the theme out there, but hopefully this gives a good overview of how they work.
That is very cool. I have the rear locker in my 4.27 rear axle on my Outer Banks, non-sasquatch. No front locker. It works very nicely. I can switch it on from the dash, or the computer turns it on in Sand mode.
Is the one you picture the same locker, or are there different lockers in different Bronco axle configurations? The Sasquatch uses 4.7 axles front and rear lockers, the Badlands non-sas 4.46 gearing.
Rocketeer Rick
Rocketeer Rick
Rick
Rochester, NY
This is the locker that Ford uses in Bronco and Ranger rear axles. The gear ratio changes don't really have any bearing on the locker itself. Whether this is the same mechanism that's used in the Jeep version of the M220 axle, I can't say, but I suspect they may have a different design over there. I don't know if the Bronco front axle is the same as this or not, but I suspect its at least generally similar.
