Manual trans 2.3L - MPG & tire size/spec ?
Efthreeoh
Hummer H3T
The differences will be in tenths of a MPG.
EveryDayBronco
Motorcycle
Why note the tire size AND gear ratio...?
webspoke
Stan
Pilot Point, TX
F450, GT350
A - 2.3L with Manual transmission = Yes
B - Average MPG = 17.5
C - fuel = 87
D - Final drive ratio = 4.70
E - tire size & spec's = SAS 315/70/17 (34.5”) Goodyear mt. 52lbs
Terrain - 80/20 highway/city
F - lift height = factory badlands
before sas wheels and tires was around 18mpg on 33”285/70/17 ko2
Blksn955.o
Greg
Wentzville, MO
7psd
non-sas badlands
4.7 gears
stock bfg 33's...well not quite 33's. set to 35-36psi.
93 octane
80-20 hwy - city
normal drive mode...well one slippery in a downpour where tornados touched down and using eco mode for 5min.
Been driving mine the first 1,500 miles not trying to run the piss out if it but not really trying to get the most MPG out of it...see where I sit driving "normally".
Been getting 17.9 to 18.4mpg
Want to do two more rotations
1. With me paying attention and changing up my habits not being a hypermiling guy but not hanging out in the left lane doing 80.
2. Using the eco mode and the above, I have noticed the power is a little muted in this mode the 5min I did run it just to see if I could "tell" or "feel" a difference.
BlueBronco
DFW
'16 F150 KR - '21 BL - 23' OBX
BL cactus moar door 2.3 man softie high tow mgv all goat modes
Average MPG = 14.9 mpg after 1500 miles
Fuel = Regular
Tire size & spec's = 37" x 12.5" x r17
Tire name: Cooper SST Pro load range D
Tire Weight: 77lbs
Lift height = Dirt Logic 3.5" over base
BoatMan
Dan
Central Washington
Ford F150
C - fuel = 87
Webspoke: how much acceleration loss do you think you had by going the larger/heavier tires and wheels?
I have a Mansquatch on order. I've been concerned about power loss vs lighter tires and wheels in a stock (non squatch) rig, but didn't want to give up the looks or features of the Squatch. I think I might go with the General ATX 275/70R18 which is a 33.2" tire in a C load range. It only weighs 46lbs. If I can find some 18" wheels in the 25-30lb range, I should be able to shave off 10-15lbs per corner on my Bronco while still maintaining a decent look. Let me know your thoughts (please).
HoosierDaddy
2dr Base
B - Average MPG = 18.9ish see my sig
C - fuel = regular
D - Final drive ratio = 4.46
E - tire size & spec's = factory 255's @ 30"
Stay tuned for new wheel/tire update in a few weeks.
webspoke
Stan
Pilot Point, TX
F450, GT350
The spec’s say the difference should be 6% in gearing loss. It felt more like 10% overall. The SAS wheel/tire combo is about 6lbs heavier, and it is all in the wheel - tire is the same weight. What I feel more is the loss of gearing.
Enabling sport mode brought the acceleration feel back to better than before ( I know it just tricks the throttle). It is decently quick once you are out of 1st gear. Without it I use a lot of throttle input to get to a nice level of acceleration. Not as snappy or responsive.
I think 275’s will look too skinny. My original badlands 285’s looked as narrow as I would go for looks. I can see 285 ko2 on the sas wheels a nice combo. Nice wide track, aggressive tread, And good gearing and street manners.
Chuck_Ruck
Chuck
Arizona/Nomadic
F150, Wrangler, Eldorado, Harley, Triumph
2dr Badlands
B - Average MPG = 20.3
C - fuel = premium
E - tire size & spec's = 285/70R17 BF Goodrich KO2 A/T(33") 57.9lbs per tire acc'd to tirerack.com
EveryDayBronco
Motorcycle
C - fuel = regular
I was hoping the base model got the advertised 20-22 mpg!
Shoresy
Land cruiser, focus st
B - Average MPG = 19
C - fuel = 91 prem at altitude 6000’
E - tire size & spec's = 285/70R17, option beadlock with 33” Goodyear MTs
Have a decent amount of hill driving and trails. 40%hwy, 40cty, 20% trails. Overall, given the weight of vehicle, tire size, and Hp the mileage is what I expected.
zombie
New Brunswick, Canada
2021 Bronco Badlands (7spd) 2022 Mustang GT PP
2dr Badlands
C - fuel = premium
Ford Bronco Manual trans 2.3L - MPG & tire size/spec ? 20211223_103017(1)
You know that pedal on the right is to go faster right? ;)
I'm somehow getting 4mpg less than you are (2dr vs 4dr aside, we have the same spec)
Chuck_Ruck
Chuck
Arizona/Nomadic
I was idling in 3rd(20mph-ish) coming into the neighborhood, I try to go slow for the kids in the area. The posted 25mph is too fast through a residential area.
