Thought I might get lucky. 400 miles, got the rocks getting crushed. 55 deg so not cold related. Crawling down the street in 1st or 2nd gear to avoid the kids, sounded terrible.
Which transmission did they install? I don't think any of the updated ones were out there yet but could be wrong? It would be on the tag which is easy to see on the side of the transmission. Probably on your paperwork as well. The updated version ends in E.Sooooo… my bronco now has about 2000 miles on it. As I said earlier in this thread, I noticed the noise immediately when the vehicle had less than 50 miles on it. And I took it back to the dealership right away. That was about two and a half months ago. Flash forward to today, I just got it back from the service dept. They replaced the entire transmission as promised. It only took them one full day to do it. That surprised me. Anyway, the rock crusher noise is completely gone for now. Hopefully Ford got this new replacement tranny right and the noise won’t come back. Just wanted to post my experience here. If you have this weird noise I would get the tranny replaced under warranty.
Unfortunately that is the original build transmission, same as what it replaced.Hmmm… paperwork says they installed MB3Z 7003 A
It's the 5-6 synchros. Some got new transmissions most likely because their dealer doesn't have qualified techs to do the internal repair. It's a bit involved and takes a few special tools.My Bronco I got back in 2021 and this noise started soon after purchase with in first couple thousand miles. The fixes are all over the place from Syncro Rings to full tyranny swaps. I didn't get any repairs done until something more concrete comes out. What I am seeing is it seems to be synchro Rings but unsure.
One thing I believe to have noticed right about the time it started making noise was that my crawler gear felt less "torquee " then when originally purchased and tested. Any ideas if it's related to a crawler gear bearing/syncro etc?
I've been away from Bronco 6g for over a year and coming back to see if any fixes have been found.
It does but has nothing to do with the throw out bearing. The 5-6 synchros are what’s rattling.Does the noise go away when you push in the clutch? If so, it’s throw out bearing. Went through 3 transmissions in a FJ Cruiser with this problem. At 60,000 miles, I punted. I have PTSD from that experience.
Did they finish the repair?Originally, mine was the same as everyone else--cold weather, in neutral, clutch released. Wanted the service manager to hear, but by the time I would drive 20 miles to the dealership, sound disappeared. Now in the hot weather, I get the grinding in 1st or second in gear while driving. Finally got the service manager to hear the noise and approve the TSB syncro fix. Take it in Monday. Hope.
