- Joined
- Feb 21, 2020
- Threads
- 112
- Messages
- 7,295
- Reaction score
- 25,600
- Location
- North Texas
- Vehicle(s)
- SUV
- Your Bronco Model
- Undecided
If you get a trim with the Bilstein Position Sensitive Dampers they have excellent bottom out control to help avoid jarring pothole syndrome. They are the standard shocks for the Badlands, Wildtrack and First Edition, part of what is called the HOSS System. They are also included with the Sasquatch Package on the Base, Big Bend, Black Diamond and Outer Banks.
Here is a highlight of the Bilstein Position Sensitive Dampers features.
Also, I'm swapping to the Falken Wildpeak A/T3W tires as they are available in P/SL load range for better ride, more information here:
What Tires Are You Going With?
Here is a good video to explain how the Bilstein Position Sensitive Dampers work.Bilstein B8 8112 (ZoneControl CR)
ZoneControl CR: Position sensitive damping with 3 compression zones and 2 rebound zones, controlled by 3 independent pistons
Compression (C): Provides superior bottom out control through a 2-stage, telescoping internal compression stop. This feature eliminates the need for an external hydraulic bump stop
Rebound (R): Secondary rebound stop will dissipate spring energy and stabilize the suspension directly following a large compression event. The internal rebound stop will also eliminate harsh top-out events and the need for an external limit strap
Triple piston design delivers comfort during every day driving conditions and maximum control under large suspension imputs
https://www.4wheelparts.com/p/bilst...ft-corner-module-41-269282/_/R-BBGL-41-269282
