Matsterious
Houston TX
2022 Ford Bronco
What's crazy? If you're talking about the number, just forget it exists. That's an engineering number, not the service part number. Almost every number stamped/molded on a part is engineering and the service part may index to that but it won't be the same.
Still in the package.
Do you have a picture of the end that goes into the oil?
flip
Phil
IN
www.ruxerparts.com
Fords
Nah, I don't think anyone's throwing shade. The problem is Ford stamps engineering numbers that don't translate directly to a service part. Then we have this gap of -A (wrong) sticks, short run of -B and now they decided to change the suffix to -F for whatever reason. Ford's part numbering system is confusing to figure out but once you understand the base, in this case 6750, you now know the base for almost every Ford engine oil dipstick. The prefix relates to the year and vehicle (for the most part) and the last stuff, the suffix, is generally a version or later variations. For example, if it ends in PTM, it's paint to match, CP is crash part.
There's just a lot of confusion with this because of the changes that happened so quickly. I just ran so warranty claims for these on folks that purchased from me and had to use the -F number instead of -B in order for the claim to go. Warranty system didn't recognize the -B since Ford already made the change in their system even though it's the same part. Technically, we should've taken a sharpie to the number and crossed out the B and wrote in F. If the part was defective, they would send a stop sale notice.
I'm not taking any offence to comments because I think I know what the confusion is. Just hard to explain in a few sentences why Ford does the stuff they do and make sense of it.
drew707
Ford Explorer
Correct me if I’m wrong but isn’t MB3Z-6750-A the one for the 2.3L.
Going back to my theory that the intended part was MB3Z-6750-B for the 2.7L but it never actually was provided to any Broncos. And it got replaced with -F because nobody bothered to put it together that nobody got the right one to begin with.
Matsterious
Houston TX
2022 Ford Bronco
I posted a few in the other stick thread but here are some others.
Ford Bronco New correct dipstick (here's part number) solves 2.7L 7-quarts engine oil capacity / maximum fill amount mystery! πŸ•΅πŸ»β€β™‚οΈ ds10
Thanks Phil!
I got the new part number ( MB3Z-6750-B ) and was wondering if was the same as the newer part number lol. What a fiasco over a dipstick! The MB3Z-6750-B stick reads my factory filled oil level exactly halfway between the two dots.
NotApplicable
BEVs
I thought we had people earlier in this thread with photos showing -B and -F were slightly different? Maybe not, I’m on my iPhone and it’s painful to manually go back scrolling.
I thought both registered a 7qt fill better than the original factory dipstick (neither showed it north of the max fill hole), but I thought -F was the same as the factory dipstick except with the twist moved up and a larger cross hatch area, whereas the -B was ever so slightly different in length, had a different twist pattern, etc?
Maybe none of this is true and I’ve just gotten confused about what was being posted about which part number.
drew707
Ford Explorer
No you are correct from what I can tell through pictures. The F does appear to be the same length as the original just with a redesigned twist location and hatch area.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
So is this a recall or TSB? I dropped my Bronco off this morning for its first oil change and the Service guy said that there is no recall or TSB for this associated with my Bronco. He showed me the screen and there was nothing.
Hi Paul! I can look into your Bronco's screen concerns on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Bronco's VIN?
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
flip
Phil
IN
www.ruxerparts.com
Fords
Oh no you didn't.......he's talking about the OASIS screen, not in-vehicle screen. There isn't a program out yet or in the works that I'm aware of.
I can tell you I've run some of these as warranty claims and Ford is calling the old sticks back. If you've got any pull, tell them to knock it off with the 700 tags. I'll send all of them back but really?
drew707
Ford Explorer
The intern bot strikes again πŸ₯±
flip
Phil
IN
www.ruxerparts.com
Fords
I've offered to help with what I can but, once corporate gets involved or offers assistance, I'm out. Not sure if they've got access to technical assistance/OASIS but some of the questions here don't always lead to or require a dealer visit. My entire professional life has revolved around Ford and service. Just sayin'.
drew707
Ford Explorer
If the account was controlled by someone who knew what they were doing we would all be better off already.
flip
Phil
IN
www.ruxerparts.com
Fords
I originally thought it was Jackson Dawson running under the Ford badge but I was wrong.
Razorbak86
Northwest Arkansas
Definitely not a bot, but also not a C-Suite executive or a member of the Critical Concern Review Group. :sneaky:
Ford Bronco New correct dipstick (here's part number) solves 2.7L 7-quarts engine oil capacity / maximum fill amount mystery! πŸ•΅πŸ»β€β™‚οΈ EF4D85F8-7927-4284-B273-D50B2D09E33F
