- First Name
- Sean
- Joined
- Feb 7, 2018
- Threads
- 1
- Messages
- 55
- Reaction score
- 86
- Location
- Porter Ranch, CA
- Vehicle(s)
- AE86 Corolla (S2K SWAP), 08 Acura MDX AKA THE GOAT
- Your Bronco Model
- Badlands
Just looks like you need more spring which is a cheap and relatively easy fix.
King private labels most if not all of their springs from Eibach and they have a of springs in a 3" ID and with a 4" free length like you need. They will be silver but You can definitely get the rate you are looking for. I would presume a 600 lb spring would probably work well but it does look like they have heavier rates as well https://eibach.com/us/i-619-eibach-silver-coilover-spring-3-00-i-d.htmlWell, King did respond back and they indicated they had not seen this issue for the Bronco yet. I assume they will get back to me on which springs to buy and replace. I think the total weight of my "stuff" in the rear is about 100 lbs. I would just think the factory setting would have easily handle 100 lbs back there. Later today, I am going to remove the fridge and the drawers to see what the results will be. FYI the top spring is SPR 3-4-500 E22 and the bottom is SPR 3-14-350 E22. Looking at the King spring catalog, the top spring is the only one they offer, for the lower spring they offer every rate from 150lb to 700lb in 50lb increments.
