Rough Country winch questions
BroncoTrail
Salt Lake City
2021 Badlands Sasquatch Lux
Hey all I have a 4-door 2.7 Badlands Sasquatch and I am researching winches. I want the winch to be as "hidden" as possible and so far the Rough Country Hidden Winch seems like the best fit. (please feel free to share alternatives)
  • Will it decrease my ground clearance at all?
  • Will it affect my approach angle?
  • Will I need to have the shocks/suspension reconfigured at all to account for the added weight on the front of the vehicle?
Thanks!
Hdscreens
Will
2dr Bronco Badlands
I’m curious as well for a stock badlands non-squatch 2dr?
dcaero
Bronco OBX SAS
Thanks!
I have 2.7 sasquatch and dis the hidden winch.
Ground clearance and approach angle, no not really. Didn't measure before and after but it can't be much if it's anything at all.
I did not adjust any suspension bits and it performs just as before.
There's a long thread out there that has tips on the install.
sklnbnzaz
Graham
Phoenix
Bronco, Ranger
Here is what I know... (This is from a friend's experience, not my personal experience)
  • The winch does not like being dunked in mud or water - her's shorted out and fried after a day of play in the mud and water (she lost her alternator that day too, nobody is sure if they were related or not).
  • Their solution is going to be to should relocate the control box up under the hood and seal up all the connections at the winch, should help with this issue (RC did warranty her winch and were great about it from what I understand)
  • Reaching free spool is difficult at best with the hidden mount so they are building a rod to connect up so they can turn the free spool from under the hood
  • Recommend a circuit breaker to cut power to the winch when not in use
  • Base Sasquatch - no real clearance issues that I have seen or they have reported, she takes that thing everywhere!
Happytown
Ryan
Zachary, Louisiana
2013 F150 Eco SCREW 4WD
I thought the RC Hidden mount was a definite no-go with the 2.7 because of the intercooler position?
EDIT: Nevermind.
BroncoTrail
BroncoTrail
Salt Lake City
@Happytown from their site:
  • Requires modification of factory oil cooler coolant lines and relocation of oil cooler components for V6 models.
  • Requires relocation of solenoid box for V6 models with included bracket.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
@Hdscreens Check out my build journal. I’ve got the RC Hidden setup, with a custom freespool rod that I machined and welded up. The trick for this is to notch it around the crossmember or simply get a higher end winch with Bluetooth controls/freespool.
In my last post I just swapped to 4DR 2.7 Auto Tow springs and got about 1”-1.5” of lift back out of the nose and the about 1” in the rear. With the added weight of mods, the new springs behave much better on road. Almost as if the shocks aren’t getting as… saturated during cornering and braking.
I’m quite happy with how it’s all coming together.
As far as it goes for @BroncoTrail … you may want to consider some heavier springs, or a perch collar lift to add preload (synthetic spring rate, if you will)
swooshdave
Portland, Oregon
Mustang
Mtns, CO
23 Bronco, 75 ScoutII
I'm considering the RC hidden mount for my 2.3L Sasquach. I'm wondering if I should just go with one of RC's winches -- are they any good? is there a good reason to modify stuff to use a Warn?
swooshdave
Portland, Oregon
Mustang
I had considered the RC winch but I'm leaning towards the HF. Located where it's at the winch will see a lot of water and the HF is better sealed. And the HF just has a better reputation.
As for Warn vs HF, that's an expensive decision.
BroncoTrail
BroncoTrail
Salt Lake City
I wound up going with the:
  • JCR Bronco Winch Plate | 6th Gen (2021+) MOD Steel / Capable Bumper
  • JCR Bronco Front Camera Relocation Bracket | 6th Gen (2021+)
  • Warn VR EVO12-S Winch w/ Synthetic Rope
Jim Walter
Athens Ga
2015 JKU
Thanks!
The hidden winch on the 2.7 is a B$&ch to install. Requiring relocating lines and such to make it fit. Works well on the 2.3. I finally went with their winch mount on the front of the modular bumper.
