It’s not about Ford letting you do it, just do it.Nope
We haven't even seen the multiple goodies yet either! Think how horrible that will feel.Same. I just can’t afford it. ?
Hopefully just some time, a couple different connectors and some wire.It’s not about Ford letting you do it, just do it.
I would think so, they are not going to change the body to accommodate a tail light. The lens and design will differ but the base will be the same. As for the plug it will be the same, if not easy to swap out.Is that typically plug and play?
yeah, my concern was the electrical stuff. I actually do like the old school looking headlights better but the led tails with more white are more appealing to me.I would think so, they are not going to change the body to accommodate a tail light. The lens and design will differ but the base will be the same. As for the plug it will be the same, if not easy to swap out.
Real easy to swap the BD standard tail lights over to LED. I will be doing that.
No reason you can’t, it won’t be available right away though. You can get pretty much anything you want and the electrical in these vehicles are just about the same. You might have to run something back to the fuse box but it’s always doable. Companies always come out with harnesses that allow that functionality. It’s still going to cost you like $1000 because the headlights will be a good $6-700 of that.
*Elephant in the room* - software functionality/computer issues
Absolutely Ford will let you do that..... Do yall think Ford would let me order a Black Diamond and just switch the headlamps and taillamps to the L.E.D versions?
Did you simply replace halogen bulbs with LED bulbs which use the same halogen socket?headlight revolution.com does a lot of connections. I did LED from standard halogen lamps as plug and play using these guys.
It was a simple plug and play. I removed the bulb and housing and replaced with a JW speaker LED assembly. The connections were different but headlight revolution included the necessary conversion pigtail that converted oem to led connection. The pigtail was like 4” long, nothing major.Did you simply replace halogen bulbs with LED bulbs which use the same halogen socket?
Or did you fully re-wire and retrofit an entire housing, converting to LED's, utilizing the factory pigtail canon plug?
- If so, did the factory utilize different canon plugs by trim?
And then there are those of us who come back everytime Ford tells us the B&P are around the corner when they realize we're getting impatientI love this forum.
"I big man. I drive stick shift. VERY difficult. Me Sasquatch. Small tires bad."
The other half of us: "We just want signature headlights and a 12" screen."
