Updated: RAKET “Multi-Top” Roof Rack
RAKET Roof Rack Poll….Would you rather have a...
  • Total voters
    107
Status
Not open for further replies.
WheelMe
Patrick
Northern California
2022 Bronco Badlands Sasquatch 2.7L
The front brackets and rear towers can stay on, even without the basket installed, is that correct?
Is this the "slimmed down" version of the tower that we're seeing in the latest photos here? It looks good in black, and may look even better if slimmer. Good work!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Great question. Here’s the pro/con:
Con: You can’t leave it connected since the MARK II tower is also going to be lower.
Pro: We’re using Pem fasteners for the 6 bolts, so this can be unscrewed in less than 5 minutes.
Pro: The final tower should be closer to >50 pounds, so an easy lift/drop top/reattach won’t be too difficult.
Didn’t your original plan include quick release tower crossmember? Can you briefly explain the process from fully on to fully down (position 2)? Loving the look/functionality of position 1 so far.
JohnnyBronco
Pennsylania
X4
exactly. I’m sure they work well for others but the RAKET system will work with/without the top on. I’m hoping the weather improves and we may test this topless (the Bronco that is). Thanks for the input.
Anyone have any idea what is behind the cover on the B pillars (the ones behind the front door) Seems like if there were factory bolt holes we could be attaching something there in the way of rack mounts. I won't be the guinea pig to pull them off and be unable to reattach
RAKET
RAKET
Derick
www.raketdesigns.com
Yes…the front assembly will be 3 inches lower with an improved approach angle. It will double as a lightbar mount. The rear tower doubles as a molle panel accessory independent from the basket. Lastly the basket is REVERSIBLE so you have a basket…or a flat surface capability. Here’s a quick picture I just took. The final product will be (imo) a game changer.
Thanks,
Derick
RAKET
RAKET
Derick
Thanks. I don’t think we ever had a quick release for the crossmember. We rely heavily on the structure to keep our load capacities high. So here’s how our patented system works.
1. From fully installed and top on, remove 4 fasteners in the basket, and SLIDE the basket off :)…whaaaaat!! lol
2. Remove the 6 tower fasteners (3 each side) then lift/remove the tower.
3. Follow with the standard top-drop process.
4. Reverse process 2 and 1.
The benefit is it works with hard tops as well, so if you decide to switch at some point, there’s no need for a new rack system. Here’s the bonus…the basket is reversible, so you either have a basket or a flat surface for canoes, skis, boards.
Ford Bronco Updated: RAKET “Multi-Top” Roof Rack F7D46F52-2EDD-4DCC-A750-9A908E7F8109
RAKET
RAKET
Derick
I believe someone does utilize those, but limited to the top being off.
redone17
Cold Spring, NY
@RAKET - thanks for that explanation. I’m really excited to see the next iteration.
Do you remove the towers from the base - so, the sides/molle are removed too? Or just the top portion that goes across the roof?
RAKET
RAKET
Derick
The tower is one piece. You separate it from the side mounting brackets and lift the system off the Bronco. Leaving it on is an absolute option as shown here:
Ford Bronco Updated: RAKET “Multi-Top” Roof Rack F290B703-E997-48BF-9464-39D2F1AE6731
redone17
Cold Spring, NY
Ok, that’s more work that I had originally anticipated - BUT, that being said - after two summers with a soft top I was in position 1 nearly every day and position 2 - I can count on one hand.
RAKET
RAKET
Derick
I am 100% in the same boat. Since I’ve had my Bronco l’ve only been in position 2 a handful as well. The design of position 1 is plenty to get sun. Also, it may seem like a lot, it it takes less than 10 minutes (especially if you have someone helping).
zerk4321
Erik
Fairfax, VA
Base Squatch Rapid Red
So, can the rack (basket) be on with the top in position 1?
RAKET
RAKET
Derick
Great question; the answer is no. Position 1 puts the top up high, which would interfere with the basket. You can easily (4 bolts) take off the basket, then position 1 works.
Bemcnamara
Brad
Coeur d'Alene Idaho
2015 F56S MINI
It's nice that the basket is reversible, but I would still prefer a flat deck option if you made one.
JediMcMuffin
Tommy
2021 Bronco Badlands
I like that the rear towers can stand apart. Could I strap something like a 10x10 canopy to just that piece across the top?
RAKET
RAKET
Derick
Understood. It would actually be easier so we may make it an option. I would assume load capacity will be less, without the added frame.
Status
