Winch on Bronco Outer Banks with Lux Package & Modular Bumper
Dandeisel
Shadi
Philadelphia
2022 Ford Bronco
Does anyone know a workaround or know of a company that sells or installs a winch on a Bronco Outer Banks with modular Bumper and Lux Package? I can't for the life of me find any company that does this. I've found several aftermarket companies that sell winches and mounts but I'm concerned they don't have relocation mounts for Front Camera, and all the Safety sensors like Parking and Collision warning sensors.
Any feedback would be greatly appreciated.
May have to go with a Rear hitch-mounted winch if no solution.
NC_Pinz
Central NC
2022 Ford Bronco OBX w/ Squatch, 1975 Ford Bronco
Rough Country
NC_Pinz
Central NC
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
JCR Off-road winch plate and camera relocation kit with the DV8 ACC relocation kit is what I installed.
https://www.jcroffroad.com/product/BR6SB-WP.html
https://www.jcroffroad.com/product/BR6FCM.html
https://dv8offroad.com/collections/...co-adaptive-cruise-control-relocation-bracket
nkyhunter
mark
nky villa hills
2022 BRONCO,2021 JL RUBICON,2022F150 TREMOR
on the ACC relocation kit do you need to recalibrate the system for it to work correctly??
JohnnyBronco
Pennsylania
X4
You can install just about anything that does not impede air flow as designated in a diagram posted a while back. So the sensors give you a warning every time you start up? Gotta be a fuse somewhere you can pull. Not like you can't drive with sensors blocked. Mine iced up several times this winter and yes annoying for a minute but didn't stop me from being able to drive
JakeC
Jake
Dearborn, MI
michiganbroncos.club
2022 Badlands
cincicycles
Ohio
ICUGAZN
Kevin
2019 Raptor
How was the install process? Any issues? Iā€™m leaning towards this exact setup. Thanks for any insight you may have!
The winch plate install was the most difficult because I did it along, so it is doable with one person. Their video install guides are pretty good but I ran into a couple of snags. One was that when relocating the inner park sensors, after cutting away on the harness, my drivers side wasnā€™t long enough. I ended up splicing in an additional 4ā€ of wire to make it longe enough to reach the winch plate relocation spot. As for the front camera relocation, it pretty straight forward. However, the camera wire they provide is way too long. I ordered this after the fact that I will replace the long one with. https://www.ebay.com/itm/Car-Antenn...2349624.m46890.l49286&mkrid=711-127632-2357-0
The ACC relocation is pretty simple, but there is some cutting you have to do for it, itā€™s very minor.
CO_Lazy_Hiker
Brad
'22 Badlands
Have you had any issues with the acc after relocating it? Have seen some other comments that people had spotty performance, interested to hear your experience.
ICUGAZN
Kevin
2019 Raptor
On my first road-trip after relocating the acc, there was one issue where it like lost the location of the car in front of me. Since then it worked really well. Itā€™s like it had to learn its new position. Iā€™ve had a lot of long road trips where it has worked flawlessly, even in heavy highway traffic.
CO_Lazy_Hiker
Brad
'22 Badlands
Awesome, that is great to know! I am really struggling on winch options because I hate the idea of not using the modular bumper, just seems like such a waste to replace it but at the same time, the added functionality and just piece of mind with being able to get out of a sticky situation...
ICUGAZN
Kevin
2019 Raptor
Yeah that's why I went with the winch plate. The modular bumper is so nice it would be a waste to swap it out. Also, check with JCR's website. I thought they were working on a mod to the winch plate that did not require relocation of the ACC and now its available.
Ford Bronco Winch on Bronco Outer Banks with Lux Package & Modular Bumper 1672513263435
