Wiring aftermarket interior lighting to work with factory lights?
Cornbred
Georgia
17 F-250/Edge, 14 F150,202? Bronco Base/Raptor
My dad put some lights in the interior of his side by side that look like led rock lights, and they have a button on them to turn them on. I can't remember the brand but could be a good solution if you don't mind doing some wire tucking.
I did this in my F250. Used rock lights under seats and under dash. Wired them to upfitter switches.
2Jeeps&PatriotX1
Denver, CO
'23 4dr Badsquatch, ā€˜05 LJ & ā€˜17 F150
Ah, I didn't realize this. Good information!
This doesn't change my plans for the steps, as I intend to find a signal from the doors themselves. The dome wire would be simple, if possible, but I assume the domes come on (or stay on for a bit) even when the doors are closed, like other vehicles I've driven. I would want the steps up any time the door is closed.
This info does have me wondering about expanding the interior lighting circuit with more lights that can operate on that PWM.
Would you still wire the steps override switch in to prevent steps from opening up if youā€™re stuck on a rock? Not sure whether you plan to offroad or not.
Ksjrb03
Tx
F250
Let me know if you find some lights that will work on PWM. Iā€™ve reached the end of the internet without finding anything.
Jhuff
J
Toyota Tacoma and DR650
My first plan is to wire this into one of the upfitter switches so that I don't have to drill any holes in the dash. My plan B is to buy a smaller and nicer looking rocker switch to replace the one provided. Unless someone beats me to it, I will make a thread when I get the Bronco. Lol. Just planning right now.
Nothing found for sure. I'm assuming any LED light will work, I've read anecdotes that LED strips can be added to a PWM the dome circuit, but I don't know for sure.
Since the Pulse Modulated circuit is used to dim lights by basically quickly turning them on and off at fast intervals (longer "off" for dimmer light), I'm worried that would be hard on the "wrong" bulbs, but am hoping someone more knowledgeble pops in.
Ksjrb03
Tx
F250
Regular LEDs will absolutely not work from the dome light circuit, they just flicker dimly. Been there done that. The PWM signal is lower voltage and highly modulated. It also doesnā€™t work to trigger a relay, again been there done that.
2Jeeps&PatriotX1
Denver, CO
As the previous poster mentioned^^^ tapping into the dome light wouldn't work. A couple people have already gone down this rabbit hole even trying PWM converters from diode dynamics with no luck.
Jhuff
J
Dang. Yeah it does sound like a rabbit hole. Lol.
Ive read people talking about adding some resistors or capacitors to make lights play nice with PWM. If nothing else I might find another Ford dome assembly to play with.
It may be a little OCD, but I would much prefer that any auxillary lighting match the OEM dimming and fade out.
F1NDx
Detroit, MI
I threw a mini led strip in the cargo that auto turns on/off when opening the door. No visible wires, no hacking up the trim. Cheap & reasonably bright
Ksjrb03
Tx
F250
What about the cargo bay light? Is it PWM also or just timed?
Yes, all interior lighting is on the same PWM circuit. Front map lights, rear dome light, cargo light, and ambient footwell.
JohnnyBronco
Pennsylania
X4
Where did you put the switch?
F1NDx
Detroit, MI
I used a magnetic reed switch and I hid it under the plastic trim. I will take some pics to show where
Red circles in pics are the two halves making up the reed switch. One is visible on the cargo door (very small) and the other is hidden underneath the plastic trim part and fit perfectly.
Ford Bronco Wiring aftermarket interior lighting to work with factory lights? Screen Shot 2022-01-27 at 3.11.17 PM
Ford Bronco Wiring aftermarket interior lighting to work with factory lights? Screen Shot 2022-01-27 at 3.13.07 PM
Ford Bronco Wiring aftermarket interior lighting to work with factory lights? Screen Shot 2022-01-27 at 3.11.59 PM
Adumb
Adam
St. Louis
'21 Area 51 4dr
How is this powered?
Topher
Christopher
Pasadena, CA
2023 4 door Outer Banks, Cactus Grey, MIC, LUX
I understand about the PWM circuit and that tapping into it won't work however, I have now seen two separate YouTube videos where it appears to have been done successfully. Here are the links to them. I cannot confirm if they work or not since my 2021, 2022, 2023 Bronco hasn't been schedued yet. I'm curious if it can, in fact, be done. Maybe the cargo light is different.
Thoughts?
(at 12:50)
Ksjrb03
Tx
F250
Thoughts?
(at 12:50)
What youā€™re missing is the fact they are using the 12v hot, and a switch/remote to turn on the lights. That circuit is hot for 60 minutes after closing the door. So if you didnā€™t use a switch or remote, the light would stay on for 60 minutes. Iā€™m doing the same with some cargo lights and a switch.
What you quoted from me was for extra interior dome lights. This is an application where you want extra lighting to turn on when the factory lights do, and off when the factory lights do, without the use of a switch. There is not currently a clean solution for that because of the PWM lighting used.
