Your first 2021 Bronco mods will be?
If you could, would you change your build to an FE?
  • Total voters
    51
Jalisurr
Oklahoma
'09 Corvette Z06, '97 Mitsubishi Pajero Evo
-lights and mudflaps for sure will be the first thing
-Second set of rims and winter tires will also happen within the first year
Beyond that will depend on what it ends up coming with stock:
-If I can't keep the rear diff locked at speed in stock form, adding an override switch for that
-If it doesn't come stock with a front LSD, that will be going in as soon as there's one available.
-Same story for some good bypass shocks if it doesn't come with them
BAUS67
redneck
Central PA
37's, seeing how it comes with 35's it should be relatively easy. Rock sliders or some sort of rocker protection to keep the rock damage to a minimum. I like the thick plates with a step built in bolted right to the body for more ground clearance. Line-x the body to keep damage to minimum. Floor liners in case it doesn't come with a washable interior. Higher clearance/ stronger bumpers cause the OEM ones are usually trashed after the first week with me. Why do they put plastic on a bumper. Plastic 'aint gonna stop 'nuthin.
edit: and for the record no I am not a rock crawler I am a trail rider and here in PA we have rocks on our trails so if that makes me a rock crawler then so be it but I don't see it that way. You can drive a trail that is nice easy trail and then turn the corner into a rock garden, or cruise along a valley floor and then climb a hill and after the switchback is a rock ledge that needs traversed. To my this is more overlanding but I call it trail riding. NOT rock crawling.
Toyhoarder
The west
Early Bronco, F-150, F-450
High clearance steel bumpers.
BAUS67
redneck
Central PA
Strip interior and useless electronic doodads and nannies, Line-X floors, 460 stroker swap mated to a ZF 5-speed, D60s front and rear, 40s. You know, the basics necessary to hit dem forest service roads.
X2 but instead of 460, Godzilla with a 4.0 whipple. :idea:
Rogues Gambit
Eatontown, NJ
'19 Ram Rebel, '07 A4 Quattro
On a related note, how bad is the warranty work going to get with Ford if you have evil modifications?
Obviously the law says they have to prove it was the fault of the mod, but much like speed limits that law doesn't hold much water if it's not really enforced.
Depends on the dealer, find the Roush associated ones, they're lienent or in my experience, untune the car and you're good
BAUS67
redneck
Central PA
I don't see that as a problem now, not like it was when I tried to warranty my T-5 from my fox Mustang, BDS offer 5 YR / 60,000 mile warranty
https://blog.bds-suspension.com/?p=20077
scroll down a little, on the right, click on box that says factory protection plus …… not just Ford. If I have this correct because the lift kits are engineered to not change the driveline angles much, mainly driveshaft angles.
rkj__
Ryan
Ontario, Canada
Sierra, Countryman, RZR
IF a Bronco ends up in my driveway...
Winter tires + second set of wheels
Trailer Brake Controller (if not optional equipment from factory)
Amos Moses
Trae
North Florida
Ford trucks
The absolute first thing is a stop to the audio shop the day I pick it up as no factory sound system has impressed me enough to ride stock. Next would be to ship it to my sponsors to develop parts for it, put wheels and tires and that'll sum up the first 2 or 3 months of the 4dr. The 2dr will go to the audio shop, get a leveling kit and some wide ass wheels and tires.
