Aztec1382
Aztec1382
Sam
F350
Just universal ones from rally armor
CentralFLBronco
Jordan
'22 Bronco Big Bend
Added some mud flaps
Window tint
Expel on the lower doors
Jks tire clearance kit
Kicker key 200.4 and 500.1
Purchased a front bumper from svc
Waiting on powdercoat
Ford Bronco 2-door desert runner Bronco w/ custom tire carrier E90FB8A1-AE7D-402B-8482-E101A970A383
Which model kicker speaker did you go with in the rear?
Aztec1382
Aztec1382
Sam
F350
Was driving around without a bumper
Hoping a nice swing out tire carrier would be released soon.
And ran out of patience
Going with the dv8 as a temporary solution
Aztec1382
Aztec1382
Sam
F350
Purchased a set of
icon rebound pros (black)with 0 offset
Ran a hub centric ring
The offset brought the wheel out about 1.25 inches compared to the sas wheel
paired it with some
37” kenda klevar rt tires
Sent the wheels for powder
Picked them up yesterday and was able to get them mounted
You can definitely feel the weight difference from a 35 to a 37
Was averaging 18 mpgs on the 35s
Hedrock
Rome
4dr EG Black Diamond
Purchased a set of
paired it with some
Ford Bronco 2-door desert runner Bronco w/ custom tire carrier F22B2113-2A21-453B-A665-1979A85F077C
i Guess no crash bars anymore? Get it to rub yet at full lock or stuff?
Aztec1382
Aztec1382
Sam
F350
crash bars removed, went with the jks kit
no rubbing at full lock, going out this weekend to test while wheeling
Aztec1382
Aztec1382
Sam
F350
Replaced the plastic diff cover
For the oem steel
Just need to trim a small section to make it work
Aztec1382
Aztec1382
Sam
F350
Finished the king and camburg uca install
Had to figure out a way to mount the front reservoirs since i cut off the crash bars.
Purchased some weld on mounts from poly performance.
