TD723
Todd
Newton, Iowa
2020 Ram 1500, 2017 Jeep JKU
Great build, you win! I can’t wait to start on my base sas 4 door, fingers crossed they build it next week.
Slick85
Richard
Austin, TX
Do the kicker coax speakers in the rear pods sound significantly better than stock?
Aztec1382
Aztec1382
Sam
F350
The stock speakers where horrible
Sounded muffled
i think the amp was the improvement
Rick Astley
Up Doug's ass
d
Tire carrier complete
Time for the wiring
Then off to powder coat
Curious which bearing you chose for this.
Looks like great work, but if you wanted some input on grinding disc's, LMK. You, yes YOU, could be set you up on the path towards garbage welds and beautiful grinding.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Killer build. With your current lift & 37’s how tall is the MIC roof? I’m curious if my 2Door will fit in my garage.
My Kenda KR601 37’s should arrive end of next week. 🤘
cheers.
Aztec1382
Aztec1382
Sam
F350
Changed out the sub and enclosure that i had
Needed some of that space back
Kept going back and forth between the stinger and the mti acoustics. Or keep waiting for a stealth box from JL.
The mti acoustics seemed to be the best match and was slimmer than the stinger box.
Went with the 10inch kicker with dual 2 ohm
Wired it for 1 ohm so that i could get the most out of the kicker key 500.1.
Was not expecting it to be as good as my current 12 from kicker.
But dammmn im impressed.
And the best thing is that i have all my storage space back
Aztec1382
Aztec1382
Sam
F350
Raptor grille installed
Thanks to birddogoverland for posting the parts needed from ford.
i was waiting on this to finish up the 3 middle lights
SPV Parts Harness System Bronco (& Bronco Raptor) Parking/Headlight Co (specialtyperformanceparts.com)
just small small modifications to get it to fit.
Needed to trim this piece from the bronco, and 2 of the clips on the radiator cover did not line up.
Not sure what color to run on the morimoto lights yet.
debating between a ford amber or the more yellow Amber on the preset app
Ford Bronco 2-door desert runner Bronco w/ custom tire carrier A547D0CC-CB54-48F8-B52B-51EFEA8BAFAC
Ford Bronco 2-door desert runner Bronco w/ custom tire carrier 9FD2D44E-296F-4E52-B06D-05F8C4555E35
Ford Bronco 2-door desert runner Bronco w/ custom tire carrier 7D43D8F0-C46A-4615-9059-10CF2D4EC13E
Ford Bronco 2-door desert runner Bronco w/ custom tire carrier 703AB209-B6EA-4A06-80EA-3A85DDB9D91D
Ford Bronco 2-door desert runner Bronco w/ custom tire carrier A9F68B5E-F25B-465D-9383-7756979FC72A
everything wired up
Aztec1382
Aztec1382
Sam
F350
Made some changes on forscan
Had to use the previous version 2.3.5.0
to get the goat modes to write to the abs module.
also attached a picture of my tire setting
On forscan
Speedo matches perfect with the gps speed
37x12.5-17 kenda klever rt
update had to lower the tire circumference value to 2760 which is the max the pcm and awd modules will read
Ford Bronco 2-door desert runner Bronco w/ custom tire carrier 7749E547-E4A9-43C6-BC96-3EFFEC7F4F9D
Aztec1382
Aztec1382
Sam
F350
Borrowed a go pro 360 camera
to try it out.
Definitely buying one for a trip i have coming up.
