4A/4H Pulling left on mid hard acceleration...
James Cole
MX
Badlands Sasquatch (hopefully)
Hello guys,
Today I just noticed the Bronco pulls to the left when accelerating 1/2 to full throttle only when on 4A/4H... Is this normal? If not what should I check for?
Thanks!
JC
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
when you view the power distribution graphic on the driver's console,
do the green bars for the right and side match under half to full throttle?
is there a significant crown on the road you're testing on?
James Cole
MX
Yeah they do...
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Being extra cautious, You can double check alignment… my guess would be that even though the drivetrain is “symmetrical” in axle lengths there is still some torque steer, which is most likely the case here
James Cole
MX
Can anybody please check on their bronco if it pulls to the right or left on hard acceleration and 4A/4H engaged?
This on dry straight pavement, 4H should not be used in dry pavement and turns.
Thanks!
JC
rtaylor
R
ID
19Raptor, 22Bronco
Not normal in 4A. Check tire pressure & alignment. Bronco is underpowered so torque steer not likely.
James Cole
MX
Tire pressure is the same 30psi on both fronts.
Wouldn't alignment have the same effect on 2WD and 4WD?
Thanks
JC
Techun
Pa
BD, 2.7, MIC, 4dr
Do you think that power distribution graphic displays real data
rtaylor
R
ID
19Raptor, 22Bronco
Only pulls when front wheels powered. In 2H the behavior would be tire wear or drift. It could also be other drivetrain or brake issue, but less common so best to check alignment first.
James Cole
MX
Well it is a bit subtle not like run you out of the road hard…
JerryC
Memphis
2022 Bronco
Swap front tires to opposite side and see what happens.
Lcubed
l
UsA
i've seen some pretty interesting displays of power distribution when in a rental escape starting up on glare ice, so maybe
Lcubed
l
UsA
Thanks!
JC
do you get the same behavior if you drive down the same road in the opposite direction while in the same lane?
or does it pull in the other direction?
do not try this with other traffic on the road!
(or if cops are observing)
Nickhick
Nick
Bath twp ohio
F150 xtr, vw passat
Hello guys,
Thanks!
JC
Yea I had this at first. Ever so slight pull to the left in 4a. Don't know when but it stopped.
James Cole
MX
Your rigs track perfectly straight on 4WD?
Truck has 1,600 miles and just noticed it...
I pulls always to the left not matter the road condition or slant.
Its very slight you have to release the steering wheel and it will only pull slightly as in it wont turn the steering wheel all the way, just a touch to the left.
