JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
Thank you for your service! I was a recovery specialist in the Army in the 80s. H8 identifier after my MOS number. Actually recovered and towed the M113 with my M816 5 ton wrecker numerous times. Moved on to M88 medium recovery vehicle after that. Good times.
HAHA! Good times indeed, I drove the M113 many time in the Mech infantry, as for the M816 that was a workhorse but didn't hold a candle to the M88 VTR, that thing was a blast, thank you for your service also!!
dcg2
Don
PA
Honda CR-V
And then below that you have "Overlanding", which I think of as kind of a silly term... back in the day that was just called "going camping".
So glad to hear someone else say this!
Just causes images of preppies in LL Bean or Northface jackets sipping their double mocha Frappuccinos getting into the G Wagen.
Like hearing net minder when watching hockey... he's the f@#$% GOALTENDER.
Hulkbuster19
Mike Moore
Ca.
chevy tahoe
After 6 months on this forum I can see that there are lots of potentially new off-road enthusiasts looking to get into Broncos! This is exciting and itā€™ll be great to see the 4x4 community grow in general.
I also see lots of ā€œwhatā€™s this doā€, ā€œdo I need this or thatā€ type questions, so I thought I would lend my 2 cents on my general philosophy after having been heavy into off-roading the last ~15 years or so. With my below suggestions, I will assume that you may someday want to do some serious trails - not just gravel roads and an occasional mud rut.
  1. Get a good driveline. The number one thing I want to tell you is that I believe it as FAR more advantageous to pony up as much money as possible to purchase the stoutest factory driveline that you can get in your rig - if you even remotely think you may wheel aggressively. Iā€™m talking about making sure you spend your money on things that ARENā€™T easy to change or add on in the aftermarket / used market world.
    • The prime example of this would be axles. If you think you will someday want to run 35ā€+ tires, do everything within your power to get the M210 axles. An example of this in the Jeep world would be the Dana 35 axles - which are a serious drawback when one wants to get serious about wheeling. Especially with lockers.
  2. Which brings me to my next point - lockers! The #1 single biggest improvement I made to my ā€˜79 Bronco was adding a rear Detroit-style locker. Itā€™s simply AMAZING what happens when you get all tires turning in all conditions. Therefore - I HIGHLY recommend putting down the cash for lockers. Lockers are both difficult and expensive to add aftermarket. Adding a front locker also takes you to a whole other level.
  3. Transfer Case. Swapping or modifying transfer cases is VERY difficult post-purchase. Therefore - get the best transfer case you can afford. Specifically, lowest available gearing is what you are after. Secondary transfer case features like automatic engagement are also highly valuable, but may not be justified as needed on it's own (if it were separate from the gearing).
  4. Sway-bar disconnect. You NEED a sway-bar disconnect. You do NOT need the fancy-pants electronic disconnect Bronco offers as there will be aftermarket versions available cheap, but you cannot underestimate the value of this extra articulation. Adding an aftermarket version will likely be a nice intro to DIY vehicle modifications. Disconnects I think will be even more important with the Bronco due to the already lesser articulation compared to a solid front axle.
  5. MINIMIZE any lift that you add. Itā€™s amazing how much fun you can have on a small lift and 35ā€ tires. You likely do not need >2in of lift in this Bronco to keep you happy and entertained for a LONG time. Honestly, I would recommend stock Badlands height and no lift for as long as possible. The primary reason for this is keeping your center of gravity as low as possible. High CGs equate to bad off-road handling. Good driving skills overcome lack of lift in many situations.
  6. You do NOT NEED BEADLOCKS! I regularly run 12psi in the rear, and 15psi in the front. This is plenty low to get adequate deformation of the tire (see above picture). I have only had 1 problem with unseating a bead, which was due to winch operator error (I winched myself sideways when it wasn't necessary). Until you're doing expert level stuff, save your money for those lockers ;)
In summary - Iā€™m part of a Jeep Club and I CONSTANTLY see people buying expensive D44 crate axles, paying for lockers with install labor, etc., and generally speaking they always wish they would have just bought a Rubicon to begin with. It can eliminate a lot of headache if youā€™re think you might get serious. Starting with the best available hardware to begin with has a lot of advantages.
Important Contributions From Other Members (Paraphrased)
  1. Trail Etiquette @Ramble_Offroad
    1. Never go wheeling alone
    2. Stay on designated routes
    3. Always pick up your trash
    4. Tread lightly
    5. Don't be an asshole
    6. Pay it forward
    7. Leave it better than you found it
    8. https://staythetrail.org/
  2. Wheeling Advice @Ramble_Offroad @Bronco @WillisCā€™onnors @BLTN @broncoenthusiast @BAUS67 @395N @pan-y-cerveza @RevealItAsap
    1. Understand and stay within the limits of your equipment and skillset
      • Be realistic
      • Don't let anyone (especially cute girls/guys) talk you into exceeding your limits
    2. Carefully select your line and read the terrain. Walk the critical sections first. Walking the next obstacle section of the trail is a VERY helpful.
    3. Too much throttle + hopping = broken shit
    4. Join a local club. They will have access to private wheeling ground you won't. Also a great deal of experienced people.
    5. Anticipate the effects of poor weather. A moderate trail can become nearly impassable after just a few minutes of rain/snow
    6. Don't be afraid to use it. Part of wheeling is occasional damage. Obviously don't trash your rig, but using your common sense know that damage can be fixed.
    7. Traction is everything. Minimize wheel spin wherever possible. Tire placement on obstacles is very important.
  3. Gear advice @Ramble_Offroad @Gr8Hortoni @Blksn955.o
    • You NEED a first aid kit. It can be simple.
    • Tire puncture repair kit & air compressor = gold
      • Great way to pick up 4x4 chicks err I mean friends
    • LOCKERS BEFORE LIGHTBARS!!!
      • When the rubber meats the road, ONLY functionality matters.
    • A blanket - girls love them and so do you
    • Roll of toilet paper. Definitely necessary - keep a full roll in a plastic bag. Leaves or a sacrificial sock are your alternative...
MIOBI (Make It Or Break It) - Knoxville, IA (private owned park)
Strike Ravine - Moab, UT
Iron Range - Gilbert, MN (Public DNR run park)
thank you and VERY sound advice !!
DonM
Don
Northern Cincinnati
I feel like "Off Roading" is a really broad term. It can mean so many different things to different drivers.
For me, there are sort of three sub cultures within the greater Off-Roading hobby/community. At the top end, you have Rock Crawling. I think of that as something almost entirely different/separate from "off roading". For rock crawling, you definitely want big tires, strong drivetrain, upgraded body protection, good gear ratios, etc. Then you have "Trail Riding". This is 90% of the type of "off roading" I do. Mud, ruts, maybe some downed trees, a shallow water crossing here or there, etc. And then below that you have "Overlanding", which I think of as kind of a silly term... back in the day that was just called "going camping". Ha. It's really turned into a thing in the last decade or so. For that, the off-road capabilities are secondary to the gear/set-up you fit to the vehicle for being able to camp, cook and relax when you're not actively moving.
Where you live plays a huge part in it too. I live in the southeast (North Carolina). The trails around here - in the blue ridge mountains, out in Uwharrie, etc - are radically different from what you guys out west get to play around on. We just have dirt, trees, slick rocks and lots of varying grades and inclines.
I'm torn between a Black Diamond and Badlands. Definitely getting the 2.3/MT either way. Part of me wants the beefier driveline/front axle from the Badlands, but the reality is I'd probably never go anywhere that I "need" it. Heck, I've run a 5sp Subaru Crosstrek with 150hp, no low gearing, and just stock Subaru axles all over every trail in my area and have never once gotten stuck or needed assistance. Only failure was it couldn't climb certain really steep grades. We also have a 2005 Jeep LJ with open diffs, dana 30/44 front/rear on 32s... and it's an absolute beast.
I have a feeling the stock BD will be impressively capable compared to what I'm used to. The Badlands will probably end up being unnecessary weight and complexity for my needs.
I want something halfway between a Trail truck and an Overlander. I just want to be able to road trip, camp, and wheel for fun here and there. I'm thinking a stock 4dr Black Diamond is probably the best fit for that.
If you didn't want the MGV, the Big Bend with locker could probably do the same for a couple grand less.
Broncodave
Seattle
Dodge Challenger/Nissan Xterra
My constant qoute here is always( if you're new to offroading)....you'd be amazed how far 33's and open diffs can take you.
A Badlands on 33's would be probably the consumate "work and play" rig. The driveline is fantastic, but I have issues with the rest of the amenities vs price. My favorite rig right now ....FOR ME .... is the BaseSquatch. The value is awesome for what you're getting.
So I was out today and ran across a Jeep Rubicon (4 doors) and a Ford Raptor parked next to each other. Looking at the wheels, I thought that must 33s on the Rubicon and 35's on the Raptor. I borrowed a tape measure and went back to the parking lot. Nope. The Rubicon had 31s and the Raptor 33s!
Man, there is no way I need 35 inch tires. The 33's on the Raptor looked massive. The 31's on the Rubicon looked plenty big and I liked the thinner look of the tire. And I can't imagine there is anything I want to do that that Jeep couldn't handle. I still may order a Badlands with 33's, but I'll be overdoing it for sure. Maybe I should downgrade...
This is all weird because I have 30" tires on my Xterra and they hardly stand out at all. Nobby tires and one more inch seem to make all the difference.
(Notice how in the third picture the Raptor tires actually look shorter than the Rubicon's. All in the perspective I guess.)
"NO SQUATCH FOR ME! " : )
Ford Bronco Advice for would-be Bronco off-roaders 20210107_134321
Ford Bronco Advice for would-be Bronco off-roaders 20210107_134405
Ford Bronco Advice for would-be Bronco off-roaders 20210107_134018
Broncodave
Seattle
p.s. My friend has 32s on his Scrambler and they look plenty big.
Ford Bronco Advice for would-be Bronco off-roaders IMG_3422_20201219_110226
Balthezor
Ronnie
PA
Like itā€™s a hell of a place to start. Thatā€™s the route Iā€™m going. I plan on going up 1 size to 285/75r17, just my personal preference, but other than that Iā€™m gonna wheel it just like that, and Iā€™m out trail riding every other weekend. It checks all the boxes when it comes to the extras you want in an off roader - taller gears, lockers, clearance, tires, articulation and body armor. BD is a great starting point, but if you can afford that little bit more, Badlands is where itā€™s at.
285/75r17 Is that an option?
talbot
Calgary
2dr BL AMB
ok noob question on GPS:
- built in navigation or 3rd party hand held/phone-tablet type?
off hand I'm thinking a removable unit just in case you have to leave the vehicle
- for the phone/tablet type, I believe they come with a hard gps receiver and uses mobile device software to display/input? is that correct?
just started reading up on GPS but haven't got that far yet
recommendations to check out?
HoosierDaddy
STOP RIGHT THERE MISTER!
Not even sure where to begin.
1. Mearsuring tires while on the vehicle and saying they are "XX" inches is going to be wildly inaccurate when compared to the given specs of any tire.
2. When you hear 35" or 33" tires, it is USUALLY a generalization. Many tires do NOT measure out to those numbers....they are USUALLY smaller.
The "35's" on the Bronco Samsquantch are actually roughly 34.4" inches, as measured mounted and aired up, but not on a vehicle. They are a metric size....315/70-17. Look up the conversion or specs at a site like tiresize.com .
SOME tire brands are true to size, Nitto 33x12.5 as an example, will be exactly 33" ....according to their specs, on the stated rim size etc etc.
3. learn the common tire sizes in the range we are working in.
4. get a picture or memorize the tire size you are looking at and look it up.
5. The stock tire on Raptors is a 315/70-17 ..... also called a 35", but not quite.
It is the same size as the Sasquatch tire.
6. The stock tire size on the Rubicon , lately , is 285/70-17 .... also called a 33" ...but again, not quite ....and is the same size as the Badlands standard tire.
So , unless both of those vehicles have moved to SMALLER than stock tires , which NOBODY does....
those were 33"s and 35"s you were looking at.
Broncodave
Seattle
Okay, I admit it. I don't know what the heck I am doing. I plead total ignorance, and I offer up my most humblest of apologies to the Bronco6g community.
But I will try to redeem myself! With HoosierDaddy's help, I can right this wrong!
Here are the tires. Help me dig my way out of this terrible mess I've created. Let me and everyone know, HOW TALL ARE THE TIRES?! HELP ME, BRONCO NERDS!
Ford Bronco Advice for would-be Bronco off-roaders 20210107_134442
Ford Bronco Advice for would-be Bronco off-roaders 20210107_134434
bloominguez
Tom
Atlanta, GA
'22 Br BD, '22 5BW, '95 Integra, '94 VFR, '04 SV
Why not just look at the tires and do the math? Hopefully I'll do this right...
I think I see 255/75-17s on the Jeep. That's 17+255x0.75x2/25.4 or 32.1 inches.
Looks like 315/70-17s on the Raptor. So 17+315x0.70x2/25.4 or 35.0 inches.
Broncodave
Seattle
Cool. Thanks! (y)
Where does the 25.4 divisor come from?
P. S. Anybody who's gonna roll on ā€œ32ā€œ inch tires shouldn't worry that they look too small.
dgorsett
colorado
F250, Mustang, Explorer
Yeah, my F250 has 33's (275 70 x 18) which look large, but not huge, on my F250, I think the 315's on a Squatch will be just too big. Being able to chain up is important to me and I'm not sure I could with that wide of a tire, I'd have to buy new huge, heavy chains for sure. My Rubicon has 32's which are probably about right. So my dilemma: Basquatch (get 33's later) or BB (32's, but not aggressive enough) with locker. I do like the lift of the Squatch, but like the narrower stance of the BB and it would be chainable (I think). Time to decide :confused:
