It's better then Flex seal on cardboardLooks great.. is that a bed liner coating on there?
Looks great! In some of the pictures it looks to not be the same. It’s a camera/lighting issue just like the cyber orange looks not orange at all in some pictures people postI don’t know what you’re see, but it looks the same to me.
Agree. When applying metallic paint, if you don't apply in the same orientation to every panel, it will look different. With a textured finish, you can end up with a different texture depending on distance of the gun to the panel and other factors. I'll bet these tops blow away the mic tops in terms of durability.The top is textured, so light will not reflect off of each panel the same way as I’m sure however the texture lies, the reflection will bounce differently.
Looks good. I'm interested as well if the rear cap is within factory spec, if it will fit the Bestop Skyrider dual row softop, and if they will sell the rear cap only. My initial thoughts are probably 'No' on all three.
Anderson is working on the 2Dr version and should be ready later this year.My exact thoughts! I'd love it if a 2 door version comes out (unlikely from what I've heard) & if my current sunrider would bolt up to it. I have little faith in my MIC's longevity.
no way, that's awesome!Anderson is working on the 2Dr version and should be ready later this year.
It almost looks as if the color coating or spray or finishing process on that middle panel was in the opposite direction of others.So color matching is not just a Webasto problem then?
