I just installed mine and it took all of about 20 minutes being careful and it seems to work perfectly so far and I really feel it was money well spent!
Was it cold?Anyone having issues with this? It started glitching out on me tonight. Used key fob to start truck. When I started to drive it keeps turning on and off. Then stayed off after about 10 cycles.
Thanks! Yes, it’s pretty cold about 28 degrees. I sent them a message, see what they come back with. Appreciate your response.Was it cold?
Some of the earlier models react to the cold this way.
One of mine does this once in awhile when cold.
Reach out to suppliers if it bithers you, i think they have a fix...
was happening to me last night. Sent a message to the vendor as well. I’ll post whatever reply they send.Thanks! Yes, it’s pretty cold about 28 degrees. I sent them a message, see what they come back with. Appreciate your response.
I heard back from the company yesterday and they’re sending me a replacement. When I asked them, they said that the early batch had an issue with cold temps. The new one shouldn’t have the same issue. Not happy that I’ll need to crack open the control panel again, but oh well.Thanks! Yes, it’s pretty cold about 28 degrees. I sent them a message, see what they come back with. Appreciate your response.
Same. They are sending me a replacement as well. Yeah not happy to have to do it again. Broke one clip getting it off the first time. Let see how round deuce goes.... good luck!I heard back from the company yesterday and they’re sending me a replacement. When I asked them, they said that the early batch had an issue with cold temps. The new one shouldn’t have the same issue. Not happy that I’ll need to crack open the control panel again, but oh well.
So you had no problem getting the AC housing unit off when you installed?Just installed mine, super easy and works as needed. Someone else had posted a coupon that worked when I ordered in December, might work still - FBGM was the code
Nope, did have a bit of trouble getting back on with lining up all the clips, but got it on without issue eventually.So you had no problem getting the AC housing unit off when you installed?
Jason, you mentioned they blamed it on a bad early batch. Can I ask when you actually purchased yours? Wondering what "early" is. I bought one in late November early December and hope to install it soon, was just wondering if that purchase would be considered early? Wouldn't think so.I heard back from the company yesterday and they’re sending me a replacement. When I asked them, they said that the early batch had an issue with cold temps. The new one shouldn’t have the same issue. Not happy that I’ll need to crack open the control panel again, but oh well.
I went back and found the CC transaction and it was on 9/22, so hopefully they corrected the problem before you got yours.Jason, you mentioned they blamed it on a bad early batch. Can I ask when you actually purchased yours? Wondering what "early" is. I bought one in late November early December and hope to install it soon, was just wondering if that purchase would be considered early? Wouldn't think so.
Thanks
Thanks a lot Jason. Hooefully.I went back and found the CC transaction and it was on 9/22, so hopefully they corrected the problem before you got yours.
