Availability of HOSS 3.0 parts
evilletruck
Bill
Evansville IN
2006 F350
Unfortunately Ford made it hard to just swap out the steering rack you will need to take it to the dealership ( or pony up for the FRDS software and interface ) to do it.
If you just swap it out, you will constantly get warnings about degraded performance every time you start your Bronco, there is a software sequence you have to run to tell the Bronco you are about to swap the steering rack, then swap it, then tell the computers that you have installed the new one and what its serial number is.
Unfortunately it's not something that can be done in forscan after words to update it. You have to do the full sequence in order, or you will get warnings.
da_jokker
Jeep Wrangler JKUR
But having people replace their steering racks on the trail? So you're saying they got errors by doing this?
evilletruck
Bill
Evansville IN
2006 F350
Yes, it doesn't stop you from using the Bronco its more of an annoyance. And you need to retain the original if you ever want to get rid of the alerts, since you need to connect it to start the replacement sequence
BigMeatsBronco
Allan
2021 FE 2 door
So far we know that there needs to be a calibration for sure done to most or all models to use the updated heavy duty Hoss 3.0 steering rack
BigMeatsBronco
Allan
2021 FE 2 door
Thanks this is the information my dealership is looking for
FlyingScot
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
Adding HOSS suspension after the fact should be all about the steering components.
If you want different shocks, just go out and buy different shocks... You don't need Ford.
I don't doubt this will change (hopefully sooner rather than later, but who knows these days), but at the moment, to my knowledge if you want more capable shocks without going to full coilovers and the baked-in ride height increase that comes with them, there are only two options, the Icon EXPs or takeoff/parts counter HOSS 3.0 shocks, and the Icons aren't exactly cheap for what they are.
Mad Martigan
Matt
Oklahoma
Fords and 1 Wrangler
Can a Sasquatched Badlands be upgraded to the HOSS 3.0? Relatively easy?
Never mind it's sounding like you have to take it to ford?
Evolkidbell
Northern Colorado
1966 Bronco, 2013 F-150
Headless Horseman
MD
2023 Badlands
Here what we have so far ...
Nothing verified yet, but parts are in route.
Hoss 3.0 Steering rack kit with HD tie rods
https://www.fordoempartsdirect.com/oem-parts/ford-gear-rack-and-pinion-steerin-nb3z3504m
And here are the part numbers for the 2 Dr hoss 3.0 shocks.
your link is the steering rack with hd tie rods? Should we assume the part is the same now? Also, the badlands is a rather solid build save for the darn steering and tie rod issue....would you upgrade any other hoss 3.0 parts?
Headless Horseman
MD
2023 Badlands
just following up...
userdude
Jared
Denton, TX
2023 2dr Badsquatch
My understanding is getting the stiffer steering rack (HOSS 3.0) plus maybe the improved Bilstein coils are really the only improvements outside of better belly plating you might want. Even the HOSS 2.0 isn't bad unless you want to run hard in tire pinch territories and don't want to be replacing tie rods. So my plan was to replace the steering and tie rods to 74Weld stage 3 and Ford HD tie rods that come with it and call it a day(, and later when the wallet stops smoldering the coils???), but that's maybe wishful thinking.
Headless Horseman
MD
2023 Badlands
https://thebronconation.com/broncos-boss-hoss-system-4-levels-of-performance/
Aonarch
North GA / MT
‘23 Bronco OBX 2DR Lux 2.7, ‘24 V60 Polestar
I have the Ford Performance lift kit. It’s a 2” lift with Bilstein 6100s. Set ride height. Sasquatch springs and top hats.
