Base Model Bronco Thread
Imissmy1996bronco
2022 JLU Rubicon
I wanted to start a thread on the guys/gals buying a 2 door base model. What are you doing to do to it? Auto/manual. List your buildouts here. Right now you can't get a 2 door manual with the sasquatch package, but it looks like you can get the manual with the 4.7 gears and a rear locker.....So here is my build.
2 door base
manual
4.7 gears with rear locker option
Add after market lift 2" or so...
Add 33s or 35s later
If anyone sees any issues with these options let me know. This should give us a pretty good starting point to build a wheeling rig.. I have a ranger with the 2.3 and auto and the take offs are incredibly slow and thats why I'm leaning toward the manual..
Its either this or I get the 4 door wildtrack...but thats looking like a 50k plus build.....
Where did you hear you can get 4.7s without squatch on any trim besides badlands?
You also can’t option a rear locker on the base without Sasquatch as far as I know.
That being said the manual has 4.46 gears on the base, and adding an aftermarket rear locker isn’t too bad, especially with the aux switches. Adding 33s to that should work just fine.
Also, though it depends on a lot of factors (I’ll see if I can link to my post on this), the aluminum front dif may have issues on 35s if you wheel hard.
edit: my previous post on differential strength and tire size.
https://www.bronco6g.com/forum/thre...xles-tough-enough-to-turn-35s.2599/post-83679
edit2: actually added the link this time, I clearly have not had enough coffee yet....
hemiblas
Roger
Aurora, Co
2023 base SAS Bronco, 2018 Rubi JL and JLU
I wasnt sure about the 4.7s.....I saw one of the spreadsheets that was created on this site and it had it as an option, but It sounds like it isnt. Thanks for letting me know.
You are right 4.46 gears arent a bad way to go.....
Thanks for all of the insight!!!!!!!
rcengr
Ohio
Grabber Blue Mustang Convertible
Odds of an aftermarket hard top are pretty slim. There isn’t one for jeeps after all.
There are Jeep options available. Prices range from $2500 to $4500. I imagine the aftermarket will support Bronco too.
hemiblas
Roger
Aurora, Co
It sounds like most people will be finalizing orders in the next few months. So I'm guessing this means that they wont have anything to test drive at the dealerships? I still torn between 2 and 4 door and manual/auto.
DrKennethNoisewater
Dirty South
2016 razor scooter
Remote start can be added either by the dealership or aftermarket, right? That's really the only feature from higher trims/packages that I really want. But I'm not about to drop $5K to go up to BB then another grand or two for mid package. I live in TX, so the heated seats are meh, but I'd love a way to get that AC cranking before I get in.
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2026 Ram RHO
Yes, remote start will easily be added later. For, I'm guessing, $150 aftermarket or $500 dealership.
Aftermarket one will use your existing key fob and the dealership one will be the same as OEM with new key fob. Both work well.
atonge40
Adam
Detroit, MI
2019 Ford Ranger XLT
I'm hoping an Eaton E-Locker set up will be easy with the Aux Panel. Ford offers a rear e-locker on all Rangers trims, even RWD. It's disappointing the Bronco Base won't get a (non-Squatch) rear locker option. Same goes with the tow package. I'd spend the $495 for a factory tow package.
hemiblas
Roger
Aurora, Co
With my 2019 ranger and the factory installed remote start I can get on the ford app in my phone and start the car from anywhere. I've started it from miles away...I can also open and unlock the doors. check fuel, oil usage etc. It would be worth it imo to get the factory remote start from ford just to have this feature.
Garbone
Gary
FL
Maybe dealer installed option?
vargo_939
nick
festus missouri
2012 Ford F150
2-door, base, 2.3, manual, Sasquatch = tons of fun and cheap enough that I'll keep the F150 Screw ecoboost.
I thought I read on one of the threads on here the Sasquatch will not be offered with the 7 speed manual. I could be wrong but I swear I saw it.
Fuzion2Bronco
Asher
Base Sasquatch
Went with the base 2D model with Sasquatch pkg, shadow black, 2.7,auto. Bumpers, grill, wheels will all change with upgrades as they come available. Gotta customize it some...
I’m well aware. I’m also switching from a fusion. 17 2.0
I have
Its the 2.7 with Sask Pkg cannot be ordered with Manual. 2.3 can be ordered with Sask Pkg with Manual.
DonM
Don
Northern Cincinnati
I have
Unless it's been changed, Sasquatch is automatic only.
qwertisk
qwertisk
How many people are going to upgrade the front bumper with the ford hd modular or go aftermarket instead?
also will you add the overhead aux switches?
DrKennethNoisewater
Dirty South
2016 razor scooter
Probably gonna leave the bumper alone, but I do plan on getting the switches, unless they're just outrageously expensive. Probably won't use them for much; a light somewhere and maybe wire a subwoofer to a switch just for fun :cool:
