Base Model Rear Locking Differential
Dad life
J
TN
Jeep, Tundra, GX470
Dad life
J
TN
Jeep, Tundra, GX470
That is what I spent most of my day looking at yesterday!
:p
Honestly, it's tempting to switch my basesquatch to a base. A rear true-trac would be awesome for a daily. Still, pretty expensive when you add in the R&P, carrier, install, etc. It really sucks that Ford used a welded ring gear design on the non-locker rear.
Hey Buddy
Drew
2022 Ford Bronco Base Model 2-Door 2.3L 7-Speed
I am thinking it will still be cheaper than adding the entire rear locking 4.46 axle & wiring it up?
Oh well, I will wait to see what the aftermarket comes up with for a 4.46?
Dad life
J
TN
Jeep, Tundra, GX470
Man, I dunno. The complete 4.46 locker rear is 2300ish from a quick google search. It's gonna be interesting to see how people tackle it. I should have someone to copy by the time mine gets built in 2024.
BasedBronco
Northern California
2023 Bronco 4dr
Montana Bronco
Montana
Chevy
> Factory 3.73 gear equipped Bronco's feature a welded ring gear/open differential and will require a replacement M220 Jeep JL ring & pinion to complete installation.
So does that mean the open 4.46 is not welded ?
indio22
Chicagoland, USA
Jazer
Jessica
2.7 OBX
Saw it here for $750: https://www.desertrat.com/i-23429938-detroit-truetrac-dana-44-m210-m220-32-spline-all-ratios.html
Ohh now this is intriguing. How involved is an install for something like this?
Montana Bronco
Montana
Chevy
I recall reading it's welded. I think only diffs with lockers are not welded.
That‘s what I’ve read too.
But if “my dealer said….” requires a drink, then “I read on an Internet forum….” should require a bong hit.
I would think Eaton Corp. would know more than some random dudes on B6G. I find it interesting that Eaton says it works with all ratios, and then specifically says 3.73 gears are welded, but does not mention 4.46.
Either way, that Tru-Trac is an excellent option for Base buyers. I’m seriously thinking about adding one to my Bronco, welded or not.
indio22
Chicagoland, USA
Yep when I first read the Eaton caveat only mentioning the 3.73, I was hoping that meant the 4.46 was not welded. I'll have to check where I read about the welded aspect.
Regarding the Truetrac, seems like it has some nice features, with the possible exception when a tire is fully in the air with no traction. Then it could have some limitations, especially with a manual trans if not able to adequately modulate the throttle and brakes at the same time. Here is a video I was watching related to that aspect:
On the other hand, some people are claiming the Truetrac in combo with modern automatic brake actuated traction control, performs well and does not necessarily require the user to brake as much.
Montana Bronco
Montana
Chevy
I had a True-Trac in the front diff of my 94 Bronco (and a Detroit Locker in the rear). For me, a Tru-Trac in the rear of my 6G will be perfect. My use is driving in snow, not rock crawling. So the “wheel in the air” does not bother me. A huge advantage of the Tru-Trac is that it works at all speeds. Just look at all the people surprised that their e-locker does not work above 20mph. Tru-Trac still works at 80mph, or even 102mph.
Note: I would also be interested in either a Detroit Locker or a Lock-Rite (lunchbox locker), but neither are currently available for a 6G. I’ve used both before and I’m fine with both.
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
Just a FYI, your factory rear E-locker will stayed locked at all speeds in Baja mode if you have it. A true-trac would be great for the Bronco also.
Montana Bronco
Montana
Chevy
Did not know that. Thanks !
