Base Sound System Upgrade/Build
NorthShoreBronco
Steph
Canada
www.youtube.com
21 Badlands 2D, 22 BD 4 Door
Front dash and rear pods are JL Audio C1-400x so two sets.
JL Audio C1 400x
Front kick panels JL Audio C1-650x
JL Audio C1 650x
Kicker HS10 Hideaway sub and amp (10in sub and 150w RMS amp).
Kicker HS10
-----Was VERY tempted and torn between the C1-650x and the C1-650 components.
JL Audio C1 650
Thank you. Going to copy your speaker selection. Because I don't know what I'm doing and you seem to know.
BOOM! Ordered 2 sets of the 400x and 1 set of the 650x. Thanks for the info!
Erock
US
2018 F150 Alpine edition
For the simplest builds... almost any (even the cheapest from Walmart) aftermarket speaker is better than what comes in a base automotive system, most of the time. Coax speakers usually sound better because the tweeter is better at playing +2k hertz than the mid speaker is. The better ones have coils and caps to tune them accordingly. Be careful of the ohms, 3 ohm does extract a bit more power from a factory unit, but can lead to clipping (momentary power loss) on some music. Just my .02
buzpro
Binky
Tacoma
sounds like you're not mechanically inclined either ... even though swapping the speakers is basic, please have someone do it for you ..... just remember if you break something, even a clip, these cars are too new and spares are not readily available .... YET
NorthShoreBronco
Steph
Canada
www.youtube.com
Thanks. No, I've changed speakers before, just never dove deep into the specifics. No time to dive into that rabbit hole, just wanted to know what to order. Now I just need the Bronco....
Erock
US
Passenger side rear panel
buzpro
Binky
Tacoma
you dont have your bronco yet? then why are you putting the cart before the horse .... just wait for a couple of weeks and keep following this thread
L8apex
www.instagram.com
'14 Focus ST, '21 Badlands
Erock
US
@L8apex i like the whole club series, personally, including the amps. You better let the experts weigh in though, I’m only an amateur these days.
NorthShoreBronco
Steph
Canada
www.youtube.com
Because I'm going crazy waiting for my bronco that was built on the 13th of July! I get a tiny fraction of joy from getting the accessories for it. Nothing else I can do.
Pressurized
Rod
Gilbert, AZ
Gen 6 Bronco - Jeep JKU - Wrangler LJ (sold)
Was looking at these, can the audio experts give me a critique? The sensitivities and impedance look good - just want to make sure I’m not missing something major.
https://www.crutchfield.com/p_109CL422F/JBL-Club-422F.html?tp=105
https://www.crutchfield.com/p_109CL620F/JBL-Club-620F.html?tp=105
I've used a lot of the JBL Club series. Good speakers. I typically like the tone of the Infinity's a little better, but that's personal preference. There are better speakers, like the Hertz, Focal and Morel's... But you pay for them and in the case of the Focal's and Morel's, it's nice to have a little more power than the stock amp is going to have.
Fordmanfrombirth
Gary
2022 Ford Bronco Outer Banks
Check out my friends in Tampa, Picken Party of 5 on youtube
  • Like
Reactions: TG3
TG3
2021 Ford Bronco OBX 4-door
I installed the 4” JBL 422F speakers in my OBX last week. Were recommended by Crutchfield’s. They sound great! Dramatic improvement over stock. Hard wired them with no issues. Took about an hour for all four. The rear speakers needed to be adjusted slightly to avoid pressing against the factory covers.
I plan to install the two 6” 620’s once I get the wiring harness. And add a 10” sub in the cargo area at some point.
Broncola
Hawaii
Element, ‘75 Bronco widow
Nice spot! Been awhile since I’ve done car audio, but looking like a must do now. Or I’m just tired of waiting for mine.
Couple questions. What did you end up with for speaker choices in the front? Did you set up the Kicker amp as “Bi-amp” or full spectrum?
Looking forward to your next update for the rear?
Also what are you preferred trim removal tools? I tend to use screw drivers with varying success/damage!
Yes indeed! That specific amp was the perfect size for that location. The power run from the battery and input signal from the factory harness are nice and short. Its very easy to access by flipping down the trim panel and removing two bolts if you ever need to adjust something. And lastly it makes for short easy wire runs to all 4 of the front speaker locations.
jh3113
Jake
Phoenix
Subaru Outback
Bro, why have you just been shitting all over people for asking questions and being excited about installing stuff in their new vehicle? Piss off with that.
jh3113
Jake
Phoenix
Subaru Outback
How does the Kicker Amp wire up to the factory radio?
Also where did you end up pulling 12V from? Fuse tap?
Thanks!
