Base Sound System Upgrade/Build
buzpro
Binky
Tacoma
So one 4 channel amp for the front 4 speakers, then another 4 channel for the rear pods, and then the mono amp for the sub which I forgot to mention in the updated build! It's a 10" ported kicker that is nice and compact but still puts out a great low end performance, even with the top down!
where did you place that 10" sub?
philjmatt
Phil
Indianapolis
2021 F-150
It's to the left of the cargo area right now, trying it on both sides to see if I can hear a difference in the low frequency response from the driver seat!
Not a big fan of all the yellow on the box, but it's not something I have to look at often, and can always black it out with some fabric dye!
Ford Bronco Base Sound System Upgrade/Build IMG_20210810_140714
buzpro
Binky
Tacoma
Hmmmmm, I'm not too keen on losing cargo space .... i wonder if two forward facing 6x9's could somehow be mounted on the C-column, and if so, whether a subwoofer is even needed in an open air car?
what do you think? I mean at this point we're all just experimenting right?
philjmatt
Phil
Indianapolis
2021 F-150
It's definitely possible! I enjoy a decent amount of bass in my music, but it still sounded good with the sub not wired up. Also for my specific use case if I ever do need the extra cargo space the sub comes out really easily!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
So, what's your impression? Did you do only the dash?
Had a chance to drive around a bit with the top on. Listening to everything from rock, reggae/dub, down tempo and little bit of country/bluegrass.
Overall a MAJOR improvement in the mid to high range. Guess I’ll need to look into the kicker panel pair for an improvement in the lows?
That being said…I’m coming from an incredible stock sound system in my 04 Jetta TDI which is the only thing I miss more that the extra 20MPG.
buzpro
Binky
Tacoma
have any of you used any type of sound deadeners in the Bronco speaker set up?
survivormanca
Ron
texas
nothing
Blksn955.o
Greg
Wentzville, MO
Where are you putting the sub?
I am going to see if it will fit under the front passenger seat OR just mount it to either side of the rear cargo area where space allows.
survivormanca
Ron
texas
nothing
It would be interesting to see if it could fit in the b&o sub location.
RhodeIslandRed
Northeast
www.bronco6g.com
TD5 Defenders
Front dash and rear pods are JL Audio C1-400x so two sets.
JL Audio C1 400x
Front kick panels JL Audio C1-650x
JL Audio C1 650x
Kicker HS10 Hideaway sub and amp (10in sub and 150w RMS amp).
Kicker HS10
-----Was VERY tempted and torn between the C1-650x and the C1-650 components.
JL Audio C1 650
Hey, I like this setup. I just got to the part where I can't decide between the component 6 1/2s and the two-ways. What is your thinking after a week or two of usage?
I don't even have my car yet, so the first question is there an obvious place or two for the tweeters? Thanks.
Blksn955.o
Greg
Wentzville, MO
I dont have mine yet either, MIC Misfit, bat batcher, in jail over here.
RhodeIslandRed
Northeast
www.bronco6g.com
TD5 Defenders
I dont have mine yet either, MIC Misfit, bat batcher, in jail over hear.
Oh, sorry man. I'm a soft top and built yesterday. We'll see what happens. Still shaken up from that purgatory video from today.
But if get mine, I'm throwing this speaker setup in it. I'll document.
BroncRik
Naples.FL
Explorer Sport
I am looking at similar setup as well with some Kicker 4s and 6.5s and the powered sub under seat like the hideaway or the Kenwood version. I looked at the option for the JBL Bass Pro like some others have done but worry about a rechargeable battery sitting in the truck cooking in the Florida sun all day.
My Bronco was built early last week and is in transit beginning this week. Trying to get all my add-ons now.
VictoryLights
Pittsburgh
2018 Honda Pilot
I see some people are mixing brands of speakers or even putting boat speakers in the rear. Is this okay to do? I’m no expert, but in the home theater world this is a big no-no because of timbre matching. I would think that could be an issue here as well.
VictoryLights
Pittsburgh
2018 Honda Pilot
Ideally, I would like a build where I can just swap out the 6 base speakers without adding an amp or sub. My concern is going to be the low end sound, but could a nice set of door speakers give me enough. I’m not trying to rattle the seats, just want a nice soundstage.
