- drew
- Jul 29, 2021
- 2
- 29
- 23
- birmingham,al
- 21 antimatter blue obx (sold) 22 badlands mt
- Raptor
Could you not get the manual with the BD at some point? Im ordering my 2nd bronco (had to get rid of 4door obx bc wife got pregnant w/ 3rd kid and needed bigger) and im stuck between 2 door manual bd sas or 2 door manual badlands non sas. Mine is purely a fun vehicle and my only real requirement is 2door manual with both lockers.If you are ordering a manual transmission... get standard Badlands without the Sasquatch package. It's the only option that makes sense, end of discussion, end of thread.
If you are getting an automatic transmission it really comes down to several things...
Also don't forget about Everglades if you can get your hands on one. It is effectively a Black Diamond Sasquatch with a winch, the Mid package, and the 12" screen from the High package.
- As you mentioned, if want the sway-bar disconnect, obviously you have to get Badlands
- Note that the sway-bar disconnect is a brand-new system and we do not know how it'll hold up over time. So if you intend to keep your Bronco forever and have no real need for the sway-bar disconnect, may want to skip it. When it does break, the vehicle won't let you go above 20 MPH... it would suck to have a feature you don't use prevent you from going above 20 MPH.
- If you want a leather interior, your only option is Badlands
- If you want an equipment package above Mid, your only option is Badlands.
- Note that if you add a winch, you should skip the Lux package—the adaptive cruise control sensor on the front of the Bronco makes adding a winch complicated. Also note that Ford accessory winch is not compatible with the Lux package and will block a portion of the front camera (if you get the High package).
- If you are trying to maximize towing and payload, you should go with Black Diamond.
- Even if you don't go Black Diamond, may also want to consider the 2.3L engine, saves you ~110 lbs of weight for some extra payload.
I personally would have 100% without hesitation gotten Black Diamond with the Sasquatch package... except I also wanted the manual transmission. So I got forced into Badlands (more or less).
