Bronco needs a lift and bigger tires...in my humble opinion
Rubisquatch
Pittsburgh, PA
2021 Bronco Wildrak
I was in TN and I agree the truck looks great but I also agree a lift will make it look much better. 35s on 4 door was perfect but it does need lifted slightly (yes I know the TN rig did not have the squatch lift but did have 35s). My plan is to definitely add 2” to 2.5” suspension lift. A) will look better and b) A bit more more articulation.
XirallicBolts
Paul
Wisconsin, USA
2016 Flex EcoBoost, 2010 Milan
I got a hell of a sticker shock seeing what it'd cost to upgrade an OBX to 33s+17" like the Wildtrak -- five tire+wheels gets you halfway to Sasquatch.
33s on the factory 18s is a bit more palatable but you lose some of the meatiness and the OBX painted wheels are too 'Honda CR-V' for the Bronco.
Gamecock
I agree, I’m confused by the people that keep acting like 35’s are big. I need to see more normal sized tires that most off-road rigs are running today.
I run 37’s with no lift and don’t consider that as a huge tire, more so the next step up from entry level.
What vehicle can you run 37s with no lift?
Shaymer
Shamus
Connecticut
Old Jeeps, old Subarus, old BMWs
I didn't like the Orange until Doug's review.
Base, Sasquatch with black top, wheels, and trim looks solid.
I agree. Bronco from the factory is too short. Needs a lift regardless of tire size. IMO, the Icon4x4 redo of old school Broncos (with 33's) look about right. (top photo). They are about 5" taller than a Badlands on 33's.
I photoshopped a Badlands from the Ford colorizer and gave the one on the lower right about a 2" lift. Much better than the factory one on the lower left.
Ford Bronco Bronco needs a lift and bigger tires...in my humble opinion 1602855417517
The white top and wheels looks sensational
BellyRat
F250
I kinda thought same until I saw in person last week in TN. The 2 door Badlands on 33s was fine - and actually better than fine. I was also thinking of going bigger, but I don’t feel that way now after seeing in person. The proportions are good on the truck - pictures and videos don’t do it justice.
Not on topic for this thread, but I gotta say that I’m totally fine to wait. I read of others frustration, but this rig is so sweet that it’s totally worth it.
Was in TN also and I completely agree with you on the 2 door and 33's. As far as the 4 door with the Squach package...I think the 35's are the right size for the 4 door....but it could use a little more lift. wasn't to thrilled with the fender clearance.
tshaw2009
Tony
Lebanon, MO
2011 F150 Lariat, 2018 Ford Edge Titanium
I happen to be in agreement with the OP. The 35s on the Sasquatch package look fine and all but it's not quite "there" yet. 37s seem like that sweet spot where it just looks "right". I would imagine that the only thing needed to fit 37s on the Sasquatch package would be a very simple 2" leveling kit and about 2 hours of labor. I'm very much looking forward to it.
NCOBX
H2 Hummer, Holden Commodore
My H2, I can run 38s by cranking my torsion bars but I’m comfortable at 37s for now as they do everything I ask of the truck without hurting power. They also help fill out the wheel wells better than the stock 315/70r17 and tie in everything.
There’s also a couple people running 39.5” tires with no suspension lift but that involves trimming and a couple other things.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Dudes, pretty sure that Cyber 2D “Concept” In the vid above Is a not a real vehicle. I believe it’s basically a big 3D printed model, no engine, it’s a empty shell. It’s stance is not realistic.
Per the original question, I agree. Even the Sasquatch builds look like they need a 2/3 inch lift. Not sure what will be workable given CV angles but it’s feasible. Proper 37’s (bfg’s 37 don’t count) are also TBD. I’d wager we can make them fit but “Are the axles strong enough for 37’s” is the question.
Peace.
Rocket Rick
Rick
2019 Ford Ranger
I think I'll match what I have on my 2011 F150, 6 in lift with 35's
Ipe
Peoples Republik of mASSachusetts
2019 F350, Expedition, Defender, JKUR
I'd like to be on 37's with the least amount of lift needed to run them with full up-travel. Preferably from the factory. Having been down the JEEP, Just Empty Every Pocket mish-mash mod path getting everything from the factory would be worth its weight in gold.
