- Ron
- Jul 22, 2020
- 23
- 216
- 307
- Pittsburgh
- 2021 Bronco Wildtrak
- Wildtrak
So, I just changed this setting. I took a quick drive around the block and it seemed to make a noticeable difference. The engine sound is still there, but it's much less prominent. So, hopefully, it's just the "real" engine noise in the cabin now. I'll pay attention as I drive it more. Any idea if this setting changes any other sounds?Okay just called my buddy. It is part of the ANC setup so yeah more prominent and or exclusive to vehicles with Lux. It's part of the ANC (Active Noise Cancellation) so those without Lux either get a reduced version of the fake ass engine noise or none at all. I knew it was generally complained about for vehicles with higher trims. Anyways if you have Lux there is ANC in the DSP and you can turn it off with ForScan and see if it helps make it go away. @LightRefined
My original post in the ACM (Audio Control Module) is for Software ANC. Both may need to be disabled. Also both may not work. No clue but good luck. Weiners crossed
783-01-01 *xxx xx-- C=ANC Disabled D=ANC Enabled
