- Randy
- Sep 17, 2021
- 6
- 129
- 262
- Vicksburg, MS
- 2022 Ford Bronco Outer Banks
- Outer Banks
Hey all,
I installed an aftermarket amp and subs in my 4 door lux OBX, and I'm running into an issue. Whenever I accelerate, my subs give off a hum in time with the engine, and after some googling, I discovered the engine sounds in these is fake/amplified.
Does anyone know if it's possible to disable the fake engine sound? Will I have to go through the dealer?
List of equipment used in case anyone's curious:
2 Skar SVR-12s in custom enclosure
Skar RP-1500.d amplifier
Knukonceptz 4 AWG OFC wiring kit
AudioControl LC2i tapped into front kick panel speakers (gonna need to patch into the factory sub wiring, these speakers don't have much bass below 60hz)
EDIT: Looks like the consensus is that there isn't necessarily "fake engine noise" on the Bronco's, but instead a high possibility of at least some sort of Active Noise Canceling signal being output from the B&O DSP. This sort of signal is MUCH more difficult to detect with the naked ear, but is much more pronounced if you start adding aftermarket amps/subwoofers.
Also, just for clarification: the sound I'm hearing is nothing like the whine you get from a ground loop - it's a low bass note that only occurs when I really give the beans to the throttle and the engine makes noise. I won't hear a sound at 3,500 RPM unless I'm flooring it.
There's also this thread from the past discussing the same thing: https://www.bronco6g.com/forum/threads/fake-engine-sounds-kill-or-keep.4237/
