- John
- Sep 3, 2021
- 24
- 2,410
- 2,259
- Pennsylania
- X4
- Outer Banks
Little known fact. Schaeffer produces the basic synthetic stock used by almost all other oils on the list. Nearly everyone else buys their primary ingredient from them.This is totally wrong and smacks of an old wives tale that will not die. There is NOTHING and I mean nothing that a conventional or synthetic blend can do that a full synthetic cannot do better.
At this point in time, there are more cars leaving the factory with synthetic oil than all others combined. OEMs would not spend the money on synthetic if it were not needed OR if it caused issues with the engine.
Synthetics outflow and outperform in both high and low temperatures versus conventional oils. Which, by the way, many so called conventional oils are actually blends these days.
There is ZERO tech behind that statement. A synthetic oil does not have anything in it that causes it to be "flung off" nor does a conventional or synthetic blend oil have something that makes it cling better. If that were true, you would have conventional and synthetic blend oils leading the market in R&D and sales...that is clearly not the case. In addition, look at all of the high-density powered engines on the market--what type of oil are they running? Conventional or Synthetic? Ford is the outlier here on the Ecoboost engines, most, if not all other OEMs are specifying full synthetic oils.
Here is a link to a list of 0W-30 and 5W-30 oils that meet the WSS specifications.
Link to Oils Meeting WSS-M2C963-A1 (0W-30) and WSS-M2C961-A1 (5W-30)
Schaeffer's can be a little harder to find. Check with a local farm tractor dealer. We used to use and sell Schaeffer when we sold Kubotas.
