- #16
Newer Fords have semi moody drivetrains, my brothers 5.0 in his f150 will be noisy as hell if you donât use the factory spec ford branded oil.I believe there was a member here that had developed cam phaser rattle. He noticed that going back to the Motorcraft Blend quieted them down (I think until he got it fixed).
But I too don't understand the blend spec. You can get Full Synth, Ford Spec'd Oil for cheap.
now, after having a 7.3 that will run on ATF, and a newer Subaru Ascent, that will actually give an oil warning light, if you donât use the Subaru branded 0w-20. I did my research before going to valvoline, our owners manual has the specification with additives, anti wear agents, and thermal properties. If the manufacturers oil specs donât list WSS-M2C961-A1 on the approved ratings on the oil itself, because older stock wonât have newer certifications, I would not put that fluid in my motor.
