- Thread starter
- #1
What all are you hoping is there? Minor things I mean.
I would like to see the ability to remove/replace every body panel. I mean rear fenders mostly, but also replaceable panels for the rockers, pillars, etc. This would be to replace rock-bashed parts, or to keep rock bashed parts to put on when you are going out to go play.
Also, the ability to turn a lower trim Bronco into a higher trim down the road, with bolts/screws. i.e. have the same bolt holes/weld points/mount points between different trims, or as much as possible to facilitate this. Understandable that this would not likely be possible if they have SFA and IFS options.
The room to fit the 5.0 for those with the cash to do so, without having to do major cutting, like the frame cuts to fit a 460 into the 80s Broncos for example.
