The only time I had that much moisture in my cargo area was as a result of my windshield washer line having a tiny hole in it (the line crosses the cargo area next to the wire loom). I would wager that you have a leak somewhere (internally like the washer line or externally from rain) because there should not be that much condensation in your cargo area even with extreme temperature changes. Those plugs in the cubbies are able to vent moisture outwards if water does accumulate in the bottom...but your moistire appears to be coming from above that (like weatherstripping or soft top or window in hard top). What happens when you spray your car with a hose around the roof/gate area from the top down? Any water intrusion then?I ordered the rear seat delete about 10 weeks ago so I'm hoping it comes in soon. Unfortunately something has come to my attention that has me a little concerned. It rained yesterday and when I opened the swing gate this morning water poured out of the weather stripping.
It's the second time this has opened so I poked around a bit and realized my jack compartment and storage area were holding a good bit of water. when I pulled the panel that covers those areas there was water under there as well. The D-rings were beginning to show rust and the panel itself was soaked.
I'd already dried the bins before I took pictures but the photos below show the issue.
Another thread on here is chalking the issue up to condensation. Regardless if that's the case or if it's a leak has anyone here had any water issues with the rear seat delete setup?
There doesn't seem to be a leak that I can see when I hose it down but I'm with you that almost has to be the case. It's supposed to rain tomorrow so I'll have to keep an eye on it. I pulled the drain plugs in the jack and storage compartments for good measure.The only time I had that much moisture in my cargo area was as a result of my windshield washer line having a tiny hole in it (the line crosses the cargo area next to the wire loom). I would wager that you have a leak somewhere (internally like the washer line or externally from rain) because there should not be that much condensation in your cargo area even with extreme temperature changes. Those plugs in the cubbies are able to vent moisture outwards if water does accumulate in the bottom...but your moistire appears to be coming from above that (like weatherstripping or soft top or window in hard top). What happens when you spray your car with a hose around the roof/gate area from the top down? Any water intrusion then?
Yes that would be an issue if moisture is present (especially with carpet/padding) and because the spacers for the Goose Gear are wood they would absorb water/degrade. Hopefully the leak is located and you get it sorted out!There doesn't seem to be a leak that I can see when I hose it down but I'm with you that almost has to be the case. It's supposed to rain tomorrow so I'll have to keep an eye on it. I pulled the drain plugs in the jack and storage compartments for good measure.
Definitely not going to install the seat delete kit until I figure out what's going on.
Enjoy! I converted my jack cover from bolts to magnets which makes removal a snap, and I bought a Safe Jack system with accessories and they all fit in the forward cubby (along with a Rhino roll up tool bag for the Safe Jack extensions and lug wrenches). That way all my rear cubby has is my stuff for airing up and down. Much better with no rear seats!I got my Goose Gear floor, fridge slider, and tailgate installed by OK4WD yesterday.
Technician said it fits better than JL.
Technician said jack cubby is blocked by slider but if you pull the slider all the way out you can access the screws. Might have to pull the rear trim out to get Jack. I haven’t had time to play with it to determine the level of effort to get the jack and I use the fridge way more than the jack.
I've been thinking about ordering one of these for my Dometic fridge.I got my Goose Gear floor, fridge slider, and tailgate installed by OK4WD yesterday.
Magnets are great idea! I think I read you did that and forgot all about it.Enjoy! I converted my jack cover from bolts to magnets which makes removal a snap, and I bought a Safe Jack system with accessories and they all fit in the forward cubby (along with a Rhino roll up tool bag for the Safe Jack extensions and lug wrenches). That way all my rear cubby has is my stuff for airing up and down. Much better with no rear seats!
I've had the fridge strapped down for months now; it never leaves. Living in NYC I don't drive daily but make several 1200+ mile round trips to NC every year. I've already racked up 12,194 miles since Oct. Usually I only put about 10k miles a year on my vehicles, all long distance highway and off road. The Bronco is such a great road trip car I've been making extra trips to NC. The fridge is an amazing luxury for those long days behind the wheel, not just when camping!Fridge on the right huh? I feel like most people have been advising putting the fridge on the left, even though the power is on the opposite side. I can't quite remember their reasonings. I dig it, this looks good. How easy is it to remove the fridge slide for daily driving?
The magnets work great, broncorik had a very good idea.Magnets are great idea! I think I read you did that and forgot all about it.
I've been eying the Safe Jack since I first saw it, probably this thread.
