TC1
Tony
Norwalk, Iowa
2022 Bronco, 2022 Mach E, 2021 Escape, 2014 RX 450
That looks good too. How pricy is that a sheet?
I thick it was about $80 for the sheet and paid another $150 for an hour on the CNC table. I did all the design and cad files.
luvmybronco
luvmybronco
Loudon, TN
1968 Bronco sport, 1969 Bronco sport, 1990 F250 Lariat 4x4, 2015 F150 Lariat super crew 4x4
Thanks for all the comments. I want to wait and see how well the Raptor Liner holds up before I start making for others. I’ve seen a few videos of the plywood splitting after Raptor liner was installed. Not sure if the prep
work wasn’t done right or if the plywood split/cracked because it was applied to the topside of DIY tear drop trailers. Either way, I want to get some time/use out of it before I charge others to make sure everything is holding up as well as if not better than Goose Gear. I’ll keep every up to date if I see issues.
luvmybronco
luvmybronco
Loudon, TN
CNC table would be nice. Save a lot of time
RockSkipper
TX
2014 F150 Crew Lariat 4x4
Nice, my first thought after seeing your pics was you wouldn't have to worry about any water jug/propane tanks rolling around now. Nice multi solution.
Preheateddinner
S.
22 Ford Bronco BB 2D
Nice work!
timhood
Tim
Several
Didn’t really like the idea of spending over a grand on Goose Gear’s rear seat delete platform knowing it’s just plywood and Raptor liner, so I built my own and am very happy with how it turned out.
I've seen some nice DIY rear seat deletes, but this is definitely the best one. I need my rear seats, at least for the foreseeable future, but this is the way I'd go. How well does the liner hold up to the appearance of scratches? It looks so nice now, I'd be obsessed with keeping it that way. 😁
KRAKEN
Andy
North Alabama
2023 2 DOOR BRONCO, 2014 F150 XLT, 2006 F150 FX4
Well done everyone... on my list. To the OP, your work looks fantastic. Looks like you removed the rear floor under the platform, correct?... and is the platform bolted down or not?
luvmybronco
luvmybronco
Loudon, TN
I just sprayed the Raptor Liner on Wednesday. It says to not get wet for 72 hrs and nothing heavy on it for seven days. I’ll give an update if the liner doesn’t hold up
luvmybronco
luvmybronco
Loudon, TN
Yes, removed floor but kept the vinyl intact in case it ever goes back to seats. It’s bolted down using seat studs and tie down bolts
bniknar
Bri
An old EcoDriver
Looks fantastic.
@luvmybronco - could you have left the rear floor installed, or did you find it necessary to remove?
luvmybronco
luvmybronco
Loudon, TN
Looks fantastic.
Had to remove it or I wouldn’t have been able open it.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Ford Bronco Goose Gear who? Made my own DIY custom rear seat delete platform IMG_4421
Cool mod!!! Love the creativity!
watrboy
Jon
Laurel, MT
2016 Chevy 2500HD 4X4
You did an excellent job. I have cut my top piece out sign plywood, an outdoor rated plywood that was laying around. I want to just have a place for tie-downs and a fridge slide. Working out the details for locations and hardware now.
Very inspirational.
